It is currently Sat Mar 07, 2026 2:20 am
Post new topic Reply to topic  [ 646 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 33  Next
PostPosted: Mon Dec 13, 2010 9:54 pm
Bloody thing :lol: I couldnt imagine being without heat up north though jesus :doh:
PostPosted: Mon Dec 13, 2010 11:01 pm
PostPosted: Wed Dec 22, 2010 11:36 am
Not really an update, and no photos at moment :lol:
Did 450 miles on 44.3ltrs making 46mpg
In varying styles of driving, on A, B and motorway roads, in very cold conditions (engine hardly warm on most of my work runs)
Not bad :)
Compared to the Mondeo which used around 60ltrs doing 450-480 miles - 35-37mpg
Will add photos as and when I do things
PostPosted: Wed Dec 22, 2010 11:44 am
that's a marked improvement :chill:
PostPosted: Wed Dec 22, 2010 3:53 pm
Definately worth swapping them...
I do miss the heated windscreen, heated mirrors, better heater, remote locking, cruise control, lack of rust :lol:
But its not all bad ;) money saving lol
PostPosted: Wed Dec 22, 2010 8:30 pm
Thats some good mpg paul :thumbsup: :chill:
PostPosted: Thu Dec 23, 2010 10:14 pm
Yeah tis all good with the mpg and the slight bit of BOOST :lol: :rolleyes:
Few little, and slightly daft updates I suppose :lol:
A mod I do to most cars I own, just for added help in the darkness...
I fitted this:-
to replace this:-
I have these ready to go on:-
I dont think I need to explain the stickers??...
Got a drivers side colour coded mirror, as it currenty has a boggo plastic one on that side, and for 2.99 you can't moan :lol: cheap symmetry!
Also fitted 3 x aero wipers, as it needed wiper replacement, and I always upgrade to aeros!
Next thing to do is add the stickers, sort the heater out properly, wind the on boost fueling up a tad and up the psi from 15 to 18 :lol:
PostPosted: Thu Dec 23, 2010 10:20 pm
Where do you get those kinda stickers from? I'm tempted to get one of the scrappage scheme ones
PostPosted: Fri Dec 24, 2010 12:17 am
ebay
PostPosted: Fri Dec 24, 2010 12:23 am
car friend :lolz:
inbetweeners lol :thumbsup:
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Fri Dec 24, 2010 12:52 am
Nice one mate, love the stickers :thumbsup:
PostPosted: Fri Dec 24, 2010 4:55 am
hi mate what is that interior light out of cheers :thumbsup:
PostPosted: Fri Dec 24, 2010 7:08 am
PostPosted: Fri Dec 24, 2010 6:12 pm
i bet that light would fit in the fiesta si.
PostPosted: Fri Dec 24, 2010 6:33 pm
Its alot bigger, your better off fitting a MK4/5 Fiesta light with spot lights trust me
PostPosted: Fri Dec 24, 2010 6:57 pm
The mk3/4 light looks alot of hassle aswel. Think I will just stick with the one thats in.
PostPosted: Fri Dec 24, 2010 10:24 pm
But the one that is in it looks to dated so trip to the scrappy I suppose or I quick look on ebay :thumbsup:
Cheers
PostPosted: Fri Dec 24, 2010 10:58 pm
MK4/5 Fiesta one all you need to do is cut thew roof lining to make it fit, and slightly cut/bend the metal behind it, simples, and well worth it IMO ;)
PostPosted: Thu Dec 30, 2010 12:19 am
Updates.. well kind of :lol:
Been driving the Scrote more on a few more long runs and found that the Speedo is playing silly buggers on me.
eg. its all over the place, either the cable and/or gearbox is near shagged to death, which wouldnt suprise me at all :teehheee:
So a way round this, would be to fit some of these:-
As found in MK5 Fez ZS models :)
They fit straight into the Scrotes, and is the same job as like fitting them to a MK3 Fiesta. Wire up the relevent wires and add a wire from the VSS found on the gearbox to feed the signal to power the speedo needle! - Alot more accurate.
The downside being that the fuel gauge reads backwards, like it did when I fitted a set to my MK3 Fiesta. - A way round this would be to fit the sender from the Fiesta too, which isnt a hard job in its self.
Please note:- I will probably not bother doing this :lol: too lazy.. and generally have the satnav on longer journeys anyway :P
Other things, which I am actually going to do!
I have managed to get one of these off eGay fairly cheap:-
Along with a manual boost controller and relevent shitty little pipes.
This will enable me to check the turbo boost is set correctly to its standard 15psi, and once I can be arsed to squeeze my hands behind the rad with a 14mm spanner and a 4mm allen key, I will turn up the on boost fueling screw ever so slightly, and then turn a knob on the boost controller to make it up to 18psi. This will give it more beans for overtaking etc, which is a safety thing, not just for power :P
Now here is an issue, where the fook do I put this little wank boost gauge?
As I am fairly bored of life right now, due to lack of project car (soon to be sorted, hopefully ;) ) I like to do little things to keep me entertained, specially in this shite cold weather, dark nights and all that.
So I have come up with an idea.
See part of the MK6 Escort Dash:-
The clock which is circled in red (which happens to be Analogue; why the fuck Ford got rid of the digital one I dont know)
Is an oval shape... now my plan is to fit the boost gauge into that space that the clock sits, and cut/fiberglass it all in, and give it a coat of black. - I'm sure it wont be too hard, its only a little bit of fiddling about to keep me entertained inside.
I will then need a clock, so I am going to take a digital clock panel out of something else, probably have a mk3 fiesta one laying around somewhere.
Under where the boost gauge will be, is 2 redundant buttons for changing the hands on the backwards clock, and a flashing LED to tell people that it is fitted with the wanky PATS system :lol:
I plan to mould in the clock and LED from the Fiesta into this place, it will use the existing Escort wiring anyway.
I'm hoping it will look fairly neat :) - Then when the ineviatable Escort drops to bits, some chav will want to buy it for his Coz replica and pretend he has boost :lol:
I will update this thread with photos of the stickers and things, when I get round to fitting them :lolz:
PostPosted: Thu Dec 30, 2010 12:47 am
sounds good, will be the coolest diesel in town lol
I bet it will look very good when done, i always wondered why they put old clocks instead of digital ones.
