Fiesta-Si.com • View topic - 1.8 16v conversion into 1.4 si - Help me please guys!
It is currently Sun Mar 08, 2026 2:23 am
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Jan 15, 2010 11:23 pm
im getting a 1.8 16v zetec engine (115bhp)
and was thinking of puttin it into my 1.4 si.
just wondering how hard would it be 2 do and what do i need to do it? i would want to get the most out of it aswel so would be wanting rs1800 bits.
and i understand that the zetec engine has 2 mounts on the drivers side whereas the cvh has 1.
but gary (bigg1985) looked earlier and theres holes there which he thinks could be for the zetec engine mount. ill try and get a pic so you guys can confirm this but im just after some more information if any1 can help i would appreciate it.
gary thinks it would be a fairly easy conversion. and i reckon theres probably more reliability and tuning potential than a 1.6 cvh conversion.
PostPosted: Fri Jan 15, 2010 11:39 pm
In your case, I wouldn't bother as bang for buck, there isn't much potential for them unless you want to delve a bit into your pockets.
I'd say get the 1.6 RST engine in there dude.
PostPosted: Fri Jan 15, 2010 11:42 pm
i think it will do 4 now thou.
115 bhp is better than 75 lol or with a few rs1800 mods 130bhp would be lovely.
and i cant find an rst cheap enough and local enough to use as a doner car.
PostPosted: Sat Jan 16, 2010 12:02 am
Its basically the same process as fitting a 2 litre. Which there are many guides out there to follow. I think if you was to follow one of them, then you shouldnt have a problem :D
PostPosted: Sat Jan 16, 2010 12:09 am
its the mounts and loom it is.
will the zetec loom plug straight into my 1.4 interior loom, what ecu would i need coz of pats?
and does the mounts bolt straight onto my chassis?
PostPosted: Sat Jan 16, 2010 5:34 pm
you can use a pre pats rs1800 ecu with a external edis wiring loom
PostPosted: Sat Jan 16, 2010 8:25 pm
you wanna get either rs1800 ecu 2FDC or a XR3i 130 spec ecu 2FBC which is what im using
rear mount you will need to drill
same for front mount there are two holes that will need drilling out
also you need to change the car loom plug to zetec one
PostPosted: Sun Jan 17, 2010 11:16 am
everythings so awkward on a 1.4!!!
so i need zetec engine loom. and car loom plug (will that then easily wire onto my car loom?? doubt it lol)
are they awkward to drill out then??
y cant everything just bolt in like it would on a pug?? ffs! :x
PostPosted: Sun Jan 17, 2010 1:21 pm
so what will i need altogether then?
what do i do about the PATS? with ecu and the loom and stuff?
PostPosted: Mon Jan 18, 2010 9:46 pm
i got a zetec alternator, s/s cat back exhaust now and 2.0 cams
these are the holes i got in my chassis leg:
are they 4 the front zetec engine mount?
PostPosted: Mon Jan 18, 2010 10:25 pm
Heres some pics mate to show what needs doing
Rear mount
before
http://www.fiestaguides.co.uk/images/en ... ig/202.jpg
after
http://www.fiestaguides.co.uk/images/en ... ig/203.jpg
Front mount
before
http://www.fiestaguides.co.uk/images/en ... ig/305.jpg
after
http://www.fiestaguides.co.uk/images/en ... ig/307.jpg
heres a comparison pic of car loom plugs
http://www.fiestaguides.co.uk/images/en ... ig/215.jpg
PostPosted: Tue Jan 19, 2010 12:12 am
so does it all line up then??
what have you gota do just drill the holes which are there out like??
PostPosted: Tue Jan 19, 2010 12:14 am
which 1s which on the plug?
PostPosted: Tue Jan 19, 2010 12:31 am
http://www.fiestaguides.co.uk/content/e ... rsion.html
looks a right pain in the arse to do!!
mite be a bit easier on the 1.4 thou as it is more modern and has more sensors like lambda sensor n stuff.
what about pats thou? will i have to use a particular ecu?
PostPosted: Tue Jan 19, 2010 6:53 pm
PostPosted: Tue Jan 19, 2010 7:19 pm
How does this pats work then? is it just part of the ECU?? coz a 1.4 si had pats i believe
have i gota use rs1800 ecu or can i use a 2.0?
PostPosted: Tue Jan 19, 2010 7:20 pm
and whats edis?
PostPosted: Tue Jan 19, 2010 7:48 pm
not sure if this is exactly rightbut i think it stands for
electronic
distrubutorless
ignition system
older cars have a external unit on the engine bay wiring loom and newer ones had it as part of the ecu
PostPosted: Tue Jan 19, 2010 9:26 pm
aww rite cheers mate.
PostPosted: Tue Jan 19, 2010 10:31 pm
