Fiesta-Si.com • View topic - Fiesta mk4 1.8 Zetec 16v for sale
It is currently Fri Mar 06, 2026 3:04 am
PostPosted: Fri Jul 16, 2010 6:50 pm
sadly the times come for me to part with my long term project, many have seen it round the forum or at car shows including Fiesta in the park
now im not going to blow sun shine up your ass it aint perfect, and needs some work
how it drives is an issue, its a VERY raw car, more suited for a track, its got a light but juddery clutch (if you aint used to it) the throttle is very firm/sticky
the tyres are the wrong size and are too big, they hit the arches easily over bumps/overloading theyre 195/50/15's it needs 45 profiles
the front bumper needs a respray and the mounting on the drivers arch is knackered so its currently 'hanging' off
idealy it needs a replacement bumper
needs a new exhaust mounting rubber near the flexy (why its hanging a bit low atm)
theyres a missing rear antiroll bar (mk3 arb conversion,, see spec list)
the shell is a bit rusty, the inner sills have been repaired and welded, and a hole in the sills (door shut) drivers side has been plated, but sadly was only a quick job to get it through the mot
the 1.8 zetec conversion has been done right and is solid, ive personally been driving it for 4-5months doing 4000miles in it since i finished the convserion at the start of march, its running on mk3 Si 1.6 engine loom thats spliced intot he mk4 engine loom, both original 1.3 ECU and the zetec 1.8 non pats ECU's are needed to run the engine, it wouldnt even crank without either, the 1.8 ecu still needs a proper mounting spot, atm its positioned in the engine bay at bit of a bodge held in by the brake servo and chassis
as you may know mk3 and mk4 fiestas use very different engine mounts, the mk3.5 Si zetec mounting plate has been welded tot he suspension turret and the mk4 one has been removed
In my idea this car would bmake an excellent trackcar, it has the power with more potential, the handling, the raw feel about it, as it certainly aint fit for concours as it is
Current spec
Engine
:- 1.8 zetec engine Converted, 1.3 gearbox, mk4 1.8 diesel clutch
H.O inlet with 2.0 TB, Non EGR manifold with De-cat exhaust system custom made by Prospeed, in stainless steel and Powerflow stainless backbox, Escort RS turbo charge carrier and aluminium pipe to go with both heat soak protected, blue sillicone joiners and induction cone
Suspension and steering
:- lowered 60mm on Apex springs, powersteering converted, poly bushed front anti-roll bar, rear beam Anti-roll bar converted with poly bushes (Si mk3), rear Strut brace welded between turrets, both sets of poly bushes by Flo flex
Brakes and wheels
:- Mondeo ST24 280mm front brakes, standard pads and discs, standard rear drums and servo, stainless steel braided lines all round
:- 15" lightweight BSA alloys in graphite grey, 195/50/15 tyres mixed brands
Interior and Sound
:- Si mk3 16v front seats, RS1800 leather steering wheel, Ghia map lights, various painted plastics, white mk4 Si dials, relocated horn button, Ghia rear seats, stealthed parcel shelf, 1800 and fiestaturbo.com badge/stickers
:- JBL GTO series front componants, crossovers, tweeters and woofers, Infinity referance rear 6x9's in shelf, JVC (i think it is, i swapped from the Si when i bought it) 45w head unit w/auxilery input and pre-outs, four blue cathodes in boot for bootlight
Body
:- mk4 1997 Encore 3 door shell in Radiant red, standard front bumper with graphite grey lower swage line, converted to front Fog lights and mk3 Golf splitter, standard blackeye/tinted headlights, and meshed front upper grill, Zetec S rear bumper, smoothed boot wiper and handle, with fiesta 1800 livary, colour coded wing mirrors, roof strips and door handles, and graphite puma ariel
Pictures including some of the flagged issues
full car thread found Here:
Viewing is very recommended, ive been as honest as i can, it has tax till end of september, MOT till early november, its still a 1.3 on the Log book
wanting £1300ono for her
alot of bits and car for that price, and if you need be theyres a collection of original parts that you can tip into within reason with the car
contact me on here using Pm or email jonyb4@hotmail.co.uk, add my msn on same name, or call/text me on 07500393837
Thanks for looking Jon
PostPosted: Mon Oct 25, 2010 8:06 pm
i like it but isnt your price too steep?
PostPosted: Mon Oct 25, 2010 10:46 pm
i dont think this has the 1.8 in it any more as its in his si
