Fiesta-Si.com • View topic - My imperial blue fiesta - update 23/09/07
It is currently Mon Mar 09, 2026 4:36 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
PostPosted: Mon Aug 20, 2007 1:34 pm
Well, as some of you already knew, my car had previously undergone a transformation from a measely 1.4 8v PTE engine, to a slightly more enjoyable RS 1800 engine in Sept '06. However the day before ford fair this year, the head gasket decided it had had enough...
So i decided rather than messing about replacing head gaskets and having the old head checked, it was time to throw in a 2.0 engine.
Took me a few days but i sourced a series 2 silvertop mondeo engine off eBay, for a bargain at £90 delivered
It arrived a few days later, on a pallet wrapped up nicely. Got it in the van and took it to where my car is stored...
New engine, still with all its mondeo bits on it (inc useless TAXI ecu)
Engine is a little dirty so i popped to halfords for a helping hand...
Engine that will be coming out...
Car on the drive ready to be "sorted"
That's all i got up to yesterday, plan is to do the conversion over the bank holiday weekend - that's if all goes to plan. I am planning to use all my 130PS RS1800 stuff (loom, maf, and ecu) to run the engine. I know it probably won't run at it's full potential, but if it doesn't work well, i will replace all this stuff when i get the money to do so)
I will try and get as many pics as poss during the conversion, and ill update soon :)
PostPosted: Mon Aug 20, 2007 1:40 pm
excellent stuff steve 8-)
hope the conversion goes well 8-) , keep us updated ;)
nice work area you have by the way :lol: ;)
PostPosted: Mon Aug 20, 2007 1:45 pm
Nice one, great pictures too, Gunk one looks like a TV advert :)
Keep us posted 8-)
PostPosted: Mon Aug 20, 2007 2:50 pm
I really like that picture for some reason! 8-)
All the best should be a walk in the park if you went from the PTE to a zetec! :)
PostPosted: Mon Aug 20, 2007 2:59 pm
Love your car so much! :drool:
Good luck with the conversion! :D
PostPosted: Mon Aug 20, 2007 5:13 pm
PostPosted: Mon Aug 20, 2007 5:42 pm
PostPosted: Mon Aug 20, 2007 6:57 pm
What loom and ECU is it? External or internal EDIS?
Car looks very very nice there BTW 8-)
PostPosted: Mon Aug 20, 2007 8:08 pm
PostPosted: Mon Aug 20, 2007 9:34 pm
PostPosted: Mon Aug 20, 2007 10:24 pm
Yeah i've had a nose through that thread. I think his may have been running rough for 2 reasons. 1 - the timing was out, and 2 - he was using a 2.0 maf which wouldnt run properly with the RS1800 ecu. Fingers crossed my maf will run the engine ok for now :)
PostPosted: Tue Aug 21, 2007 2:49 pm
PostPosted: Tue Aug 21, 2007 3:54 pm
PostPosted: Thu Aug 23, 2007 4:10 pm
PostPosted: Mon Aug 27, 2007 7:46 pm
WELL...
Old 1.8 is out, and the 2.0 is almost ready to go in :)
Got to go to ford tomorrow morn for a couple of gaskets, and then hopefully the 2.0 will be going in!
No photos at the moment, haven't got the cable right now. I will update with pics tomorrow. 8-)
PostPosted: Mon Aug 27, 2007 11:24 pm
PostPosted: Tue Aug 28, 2007 8:09 am
getting there steve 8-)
keep us updated ;)
PostPosted: Sat Sep 15, 2007 9:58 pm
UPDATE....
Well, sorry i havent updated this for a while.
Fitted the 2.0 and got it running, for about 10 miles. Where it then decided to pop the oil filter off the back and i didnt realise, until i came to a grinding halt as the engine had siezed... :frown:
Sooooo, i decided i had had enough of zetecs for now, and went out and bought this...
a cvh turbo lump! 8-)
Picked a turbo up off Terry (thankyou!!) and i spent all day yesterday with a pal from FT.com removing the 2.0 and fitting the cvh.
First things first, we removed the 2.0 from my car. I cant really stress how easy it is to lift the engine out the top, as long as you have a nice big flat area. It only took us about an hour to get the zetec out.
Dead 2.0 next to dead 1.8 :lol:
Empty bay AGAIN :(
Then we went on to putting the cvh back together. Took the gearbox and ABS off, and decided to use my 1.6 si box as it worked out easier.
I bought a gasket set and bolts off eBay for £30 posted, which is not bad really. Also bought a pattern part water pump, as the old one looked a bit grotty.
New head gasket -
Then put the head on, timed it up and it was pretty much ready to go in. It seemed sooo much easier to time than a zetec too. We also changed the clutch plate over from the 2.0, as it looked like the turbo one had seen a few hard launches... :lol:
No pics here really but it was really simple to get the cvh up and into the bay, and it was all bolted up.
We had to use the zetec engine mount in the end. We ended up using 2 of the 3 mounting points, which you can sort of see in the pic, but the 3rd one on the zetec is in a diff place to the cvh. The other 2 fitted perfectly though! :D
Got it in, and put the rocker cover on and crossover pipe. Fitted the exhaust manifold, which turned out to be a bit of a task as one of the bolt holes had been slightly rounded previously... i was fearing the worst, but luckily si managed to get the bolt to catch some thread and it was all bolted up fine in the end. :oooh:
Inlet has also been fitted, and i think most of the hoses are in place.
Now hopefully all that is left to do is fit a radiator when it turns up next week, fit the loom and HT leads, and then double check everything and make sure everything is done up tight!
more updates soon hopefully! Can't wait to drive it!! :D
PostPosted: Sat Sep 15, 2007 10:03 pm
