Fiesta-Si.com • View topic - oh yes my new car!
It is currently Mon Mar 09, 2026 9:55 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: oh yes my new car!
PostPosted: Fri Jan 23, 2009 11:22 pm
i finnnny got my car its a fezzy 1.6 si in red whitch looks black/blue lol im going to pick it up sunday ill post pics asap lol it cost me £235 wot u guys think also i may need help later to get her back into tip top condition as she needs a mot in febuary
 Post subject: Re: oh yes my new car!
PostPosted: Sat Jan 24, 2009 12:53 pm
congrats :thumbsup:
look forward to seeing some pic's :D
PostPosted: Sat Jan 24, 2009 4:06 pm
Good stuff, glad you are happy with it.
Look forward to seeing how it progresses, you remind me of how excited I use to get :)
PostPosted: Sat Jan 24, 2009 10:05 pm
lol thanks i just rang him and there one minur misshap his got a flat tyre and destyyed it lol but im getting £50 off the proce as im picking it up at 12pm ill get pics up asap
PostPosted: Sat Jan 24, 2009 10:15 pm
Well in mate! You sound as excited as I was when I got my si! Get sum pics up when you've got it! :thumbsup:
PostPosted: Sun Jan 25, 2009 5:36 pm
right got it home just lol right if i full throttle it slowlly its ok but if u full throttle quiclkly it lags and dont rev higher but it sould deeper when it does plus half way home we lost power and was missfireing badlly but then returned back to normal what could this be im just uploading pics now
PostPosted: Sun Jan 25, 2009 5:47 pm
PostPosted: Sun Jan 25, 2009 6:00 pm
sounds like a ir of fueling issue.
try cleaning the maf as a first post of call.
also changing things like the air filter and fuel would be good as you can never tell when they were last done
PostPosted: Sun Jan 25, 2009 6:34 pm
Looks mint mate! As said above, check air filter, plugs, leads etc (just give it a general service) then if the problem still remains then you can narrow it down from there.
Just need to get rid of those lexus lights and it will be sorted!
On the first pic the front D/S headlight looks out of line, check its fixed properly and not damaged :thumbsup:
PostPosted: Sun Jan 25, 2009 10:24 pm
i no the headlight only have 2 mounts but i am reoligning them 2morro iv been fiddleing around with the interur wot u think
the lexus light are ok for now hehe my main issue is the engine and getting it though the MOT
OH AND I CAN NOT FIND ANY RUST APART FROM A 3CM CERCLE IN ONE OF THE SIILS I COULD NOT HE HAPPIER
PostPosted: Mon Jan 26, 2009 12:10 am
the maf looks ok but i have no ider what to look for what do i look for
what elce could it be?
PostPosted: Mon Jan 26, 2009 12:50 am
all the things i check whenever my zetec engine runs like a sack..
MAF
ISCV
Plugs (specially the gap, zetec engines are picky)
Plug leads
Fuel filter
Air Filter
Also if you have a CAT, it could be nackered / blocked making it run like a sack?
Try resetting the ECU, unplug the battery overnight and let it learn everything again the next day :)
PostPosted: Mon Jan 26, 2009 1:08 am
ok
1 the maf look ok but i donno what to look for
2 what does ISCV stand for
3im getting new plugs 2mooro
4what do u look for if they are nakerd
5where is the fuel filter?
6air filter is fine
7 can i check the cat by removing the exsorst at the exsorst manafuld?
PostPosted: Mon Jan 26, 2009 1:54 am
nice solid looking si, the zetecs do like to go through ht leads but i reacon its a easy fix, just don't thrash it until its sorted :thumbsup:
PostPosted: Mon Jan 26, 2009 8:39 am
hehe i carnt thrash it lol it wont let me :(
PostPosted: Mon Jan 26, 2009 10:35 am
PostPosted: Mon Jan 26, 2009 7:18 pm
need help can some one tell me or send a link of what plugs to get????
PostPosted: Mon Jan 26, 2009 7:20 pm
PostPosted: Mon Jan 26, 2009 7:23 pm
Is that you in the drivers seat?!
PostPosted: Mon Jan 26, 2009 9:30 pm
change the fuel filter and check the tank isnt just filled to the red, remove your downpipe and cat and turn it up on end. if loads of bits (tiny tiny grains usually) fall out your cats knackerd and when your reving up all the bits are blocking the honeycombe inside it thus choking your engine. with fuel, i had this issue and it was because the pump was sucking all the crap at the bottom of the tank, filled it right up changed the filter and no problems.
filter is a push in fit connector, push the two lil tabs in and pull the connector of the filter end, same for the other end.
http://WWW.S2RS.CO.UK
