Fiesta-Si.com • View topic - My new Si project BACK/UPDATED 21/07/2008
where should i put updates?
Poll ended at Wed Jul 09, 2008 9:30 pm
edit the original post so they are easy to find 50%  50%  [ 2 ]
place throughout the topic, normal replies 50%  50%  [ 2 ]
Total votes : 4
PostPosted: Mon Jun 30, 2008 10:42 pm
Just thought id post up some pics of my latest Si project
all opinions welcomed
**Edited**
As i picked her up off Ebay (many parts for sale, morettes sold)
as i intend a stripped interior, all was removed from the interior and then remembered Fords cost cutting way of painting an interior so i decided to paint the whole interior, including roof.
before painting the seat mounts for my bucket seats were welded in
and buckets trial fitted
seats were then removed and the interior masked up and painted
resulting in a not perfect but pretty good finish
then the rollcage trial fitted, has yet to be powdercoated
i wont post a spec list atm, but if anyone whats one just ask
also one quick pic of my current run-around, can you spot a link between the two? lol :lol:
21/07/2008
update -
omex 600 ecu ordered
ST170 Getrag 6-speed gearbox ordered
Carbon fibre RST bonnet ordered
Mountune WRC inlet manifold bought and collected
cheeRS
Andy
 Post subject: Re: My new Si project
PostPosted: Mon Jun 30, 2008 10:45 pm
welcome to fsi andy :D
what happened to the RS? is that the engine that was in the RS?
looks pretty serious with the cage :devil: :chill:
PostPosted: Tue Jul 01, 2008 1:26 am
PostPosted: Tue Jul 01, 2008 8:34 am
:cry:
ah the tin worm,the bane of car enthusiasts lives :cry:
looks like this is going to be a beast tho :devil: , she aimed mainly at track day's or everydayness?
that exhaust manifold looks funcky :D
PostPosted: Tue Jul 01, 2008 8:12 pm
looks like this could be a bit of a animal :chill:
keep us posted with progress
PostPosted: Tue Jul 01, 2008 10:05 pm
jonosi - i will try to keep regular pics and info up for you all to see
onslack - it will be track car spec, but everyday use. i'd rather have to replace worn out race parts than compromise and build to a lesser spec just because i have to use it everyday. I want my dream spec, lmao
PostPosted: Tue Jul 01, 2008 10:49 pm
is that an OMP 10-point cage?
PostPosted: Tue Jul 01, 2008 11:50 pm
Si-2000 - yes its an OMP 10-point, but it has yet to have some additions, bit of a bargain really, brand new, never fitted primered cage £152 off the bay
PostPosted: Wed Jul 02, 2008 1:50 am
PostPosted: Wed Jul 02, 2008 9:45 am
you like cossie wheels alot dont you :teehheee:
she's going to be an animal :devil:
PostPosted: Wed Jul 02, 2008 10:53 am
looks a bit of an animal lol looking forward to seeing the progress.
PostPosted: Wed Jul 02, 2008 8:25 pm
I have to admit i may have a small thing about cossie wheels on fiestas, shame i only have one set!
PostPosted: Tue Jul 22, 2008 12:43 am
22/07/2008
omex 600 purchased
ST170 Gearbox delivered ( woo hoo 6-speed )
Hyundai Accent WRC inlet modified and trial fitted
also am after a high-spec zetec head if anone knows of any for sale.
CheeRS
Andy
PostPosted: Wed Jul 23, 2008 1:32 am
that exhaust manifold is gorgeous. good luck for the project, so many seem to be comming to an abrupt end(including mine....for now ;) )
PostPosted: Thu Jul 24, 2008 11:36 pm
24/07/2008
Lowsi- cheers im rather partial to it myself.
i'll be seeing this project through to the end as it is replacing my current car and is being build to the spec my old aubergine Si would have met if it hadn't been written off. the bodywork is going to be identical coz i loved how it looked but with a proper engine as i only had a cammed 2.0 with tubular manifold last time.
today was a fun day, drove home after work, arrived 5.30. removed the ofab ecu took the omex and modified my loom to fit with my mate, got it running on the omex and mapped it to 10psi, so i can use it to go to work tomorrow, then went back to my flat all done by 8.30.
just quickly took a few pics of my new gearbox and gearlever (30,000 mile box!)
Also i appeared in this months fast ford, i say appeared but i mean was at the dyno day, did alright, got highest power, got a mention in the write up and managed to get myself, mine or my mate graeme's car in 10 out of the 15 'random' pictures.
yay!
mine is gray FRST
graeme's is RED with white rims 2.1 zetec
PostPosted: Mon Aug 11, 2008 12:51 am
apologies for this being a bit of a cut and paste update
more playing with the omex today, it already had sensor calibrations on it when i picked it up so those were used for ease when we first connected it up, checked them out today and the ecu was reading 40 degrees when the car was 90! re-calibrated the sensor values for all sensors after this.
also had a bit more of a play with the map and ran out of injectors! lol
scoured round the parts store, *read - garage full of 'bits of metal' as girlfriend calls them!* found some of my brother's old rover injectors, checked the part numbers and found them to be around 1 1/2 times the flow rate of my beiges. these are being fitted tomorrow and we'll see how she goes
more fun today! fitted said rover injectors and re-set flow rate in ecu and changed map to suit, with me driving and my mate Graeme in the passenger seat watching the LM-1 wideband lambda reader and laptop on-knee adjusting the fuel and spark tables. got it fuelling right at 16psi, which is where it peaks at the moment. so we are back dealing with 4th gear wheelspin, always fun.
wired the now redundant ABS light to become a shift light at 6000rpm which is quite cool and went down the motorway at 60/70/80 mph respectively and set the fuelling to 14.7:1, so i can have maximum fuel economy when on longer journeys.
had more playing with the omex over the last few days. fired the car up to go to work and it ran rough? odd, so i turned on the lm-1 reader and found the car to be running lean. popped the bonnet and had a look at the pressure gauge on my FSE valve, (an increbibly handy addition) and found the fuel pressure to have dropped off. popped the rubber bung out from the top of the tank and un-clipped the pump plug, found the pump wiring to have melted severely in the plug on both the wiring loom and on the tank as well.
jacked the car up and dropped the fuel tank out to take a look.
As this has been a repeat problem with this car i needed to find a soloution as over the last year it has melted the fuel pump relay (replaced with two higher flow relays ), melted the plug on the loom twice and now the top of the tank.
with the tank out i removed the pump and then drilled through the top of the pump/tank insert. i then ran two large gauge wires straight through the hole, with grommet, to the pump. used a petrol-resistant sealant to seal around the wires and then ran the wires through the main body grommet above the tank and straight to the pump relays. re-fitted the tank and primed the system, more pressure than before, great! turned the pressure down on the FSE and checked running again. perfect!
just attempting to sort the battery and air temp compensation tables now
please note that on the Si i intend having an in-tank pump feeding a swirl pot with two external 044 pumps to supply to the rail
went, don't kill me, to ultimate street car @ santa pod this weekend. Travelled down this friday @ 6.30am and used 3/4 tank to get there, around 200-220 miles.
went with my mate graeme in his fiesta, Andrew in his golf mk2 VR6, James in his golf tdi and Gina in her fiesta style
ran the car on this strip,
graeme without nitrous ran 15.05 @ 92.14mph
graeme with nitrous 75bhp jets ran 14.477@ 94mph
i ran a 14.4807@100.67mph on first run
14.6571@100.90mph
14.4306@102.27mph
i did 5 runs in total but missed 3rd on 2 runs.
in one race i beat an audi rs6 (07 plate) he ran 14.5194@97.53mph
and in another a C20LET powered nova blew up at half track while chasing my heels.
i was struggling for traction all through 1st and 2nd losing a fair bit of time, i let the tyre pressures down in order to fight tis but was struggling having to feather the throttle through the first gears and my rev counter gave up so had to rely on the shift light for gearchanges.
havent had any time to do anything on the car for a while as;
mums Saab broke down and i had to fix
girlfriend's Saxo wanted servicing
mates golf needed wheels and tyres swapping (8 in total)
head gasket on a friends Corsa
friends FRST broke down (fixed)
brothers Audi wanted 2 new CV joints
service and mot prep on mum's Saab
Coilovers on mates Astra
sometimes i hate being a mechanic!
but finally got round to drilling all the bolts for the cage and re-inforcing the cage mount points so some progress has been made. i have bought a carbon roof to go with the bonnet. am having a garage clearout tomorrow and we'll see what i have to put on ebay and ill get the six-speed gearlever mounted up tomorrow and when the roof arrives i'll cut the roof out.
i'll get some pictures up soon as i remember to take any, and soon as the carbon arrives
well, managed a bit today. got up early and off to the scrapyard in search of a focus gearbox mount, no luck. but did find a mondeo mount, which i didnt know but also fits the gearbox and even easier is that it simply bolts into the mondeo bay as opposed to the focus which would have to be cut from the shell. bonus!
continued the stripping taking all the mock-up parts back out, and removing the air-bag control unit and bracket and all sound deadening from behind the heater. steering column and pedal box were also removed
the engine bay was stripped ready for the engine to be swapped over stripped so that only the engine and gearbox were left. at this stage the inlet was fitted to check for possible solutions to not being able to fit the gearbox with the brake servo. so to see if various master cylinders would fit under the inlet.
also finally got round to making a template to send to mike @performance trim for my bonnet.
and took a quick photo of the BIASmotorsport headquarters
and a little teaser of my mates project
anyone tell what it is?
CheeRS
Andy
PostPosted: Mon Aug 11, 2008 9:45 am
Looking good! :chill:
How do you find the Raceland Seats, any problems with it hitting the gearstick? In my Rallye the sides of the seats fouled reverse! :doh:
PostPosted: Mon Aug 11, 2008 6:57 pm
i dont know how the seats will be with the st170 shifter but they were fine with the standard quikshifter
