Fiesta-Si.com • View topic - The Si rebirth project
It is currently Sat Mar 07, 2026 1:10 am
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: The Si rebirth project
PostPosted: Thu Apr 17, 2008 1:17 pm
Couple of pics of the new budget beast that i bought to reshell my knackered Si
Only minimal rust on a couple of spots on the arches and just the one patch by the door. Cant believe i forgot to get down and take pics of the sills,They look fine though.
Bargain £255
PostPosted: Thu Apr 17, 2008 1:49 pm
Arches look minty mint! :)
PostPosted: Thu Apr 17, 2008 1:51 pm
Whatever rust i do find will be rubbed back,Treated and protected then covered up with an xr2i kit lol
PostPosted: Thu Apr 17, 2008 2:04 pm
The Nude Numpty
The Nude Numpty
Good luck with it dude, Should make a good project and you can get it all sound and mint.
PostPosted: Thu Apr 17, 2008 2:58 pm
Im thinking rip the engine out 1st and install the Si engine.Get that out of the way asap.
Only thing im thinking is its not going to be a straight swap for the engine is it due to the loom where it connects to the interior loom.Im guessing im gonna have to gut the inside and swap for the interior Si loom aswell.
Haha i think i need a week off work
PostPosted: Thu Apr 17, 2008 5:08 pm
Does it have power steering ? :D
Looks minty tho, nice find 8-)
PostPosted: Thu Apr 17, 2008 8:52 pm
Nope it has no power steering so i will be swapping the whole lot over from the old Si.
I've already made a start on stripping it, Removed...
Radiator,Coolant,headlights and unplugged most of the loom and tucked it out of the way.
BTW the green shizzle is hammerite rust remover gel.
PostPosted: Fri Apr 18, 2008 9:44 pm
Looks a mint shell!
Good lck with the conversion!, IMO if it's a route you'd be going down anyway, why not try and source a 2.0 for it, and throw it instead of the 1.6? ?Just whilst everything is in bits.
Any plans regarding styling as of yet? The modded Si bumper staying?
PostPosted: Fri Apr 18, 2008 10:08 pm
styling out to be bog standard, lowered a touch with si alloys. :chill:
thats just my opinion anyway
i wanted to do a project like this a while back hope it works out
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Fri Apr 18, 2008 10:38 pm
are you putting the bumpers onif so white si!!!! rare!! :)
PostPosted: Fri Apr 18, 2008 10:55 pm
You dont see many mk3 shells in that condition :shock:
Just a quick thought do you need power steering? Apparently you can get a non assisted "quick rack" which helps with steering response not sure where you get them from and for how much but worth a thought. I considered looking into it when my powersteering rack failed the mot as I will probably be mostly using my car for track days.
Anyway good luck with the project. :)
Tied
PostPosted: Sat Apr 19, 2008 12:00 am
you could always go with a sportKA rack and SportKA lower arms to give you a bit wider track ;)
PostPosted: Sat Apr 19, 2008 2:38 am
The plan will be to fit the 1.6 engine i have.When it eventurally dies ill throw in a 2.0 silvertop.My XR2i is going to be the Zetec Turbo fun car. This white mk3 will be cleaned up and fitted with XR2i front bumper,skirts and arches with the rear bumper from my Si *the one with those grills*.
BTW picking up a nice shiney new set of Eagle con rods this weekend :D
PostPosted: Sat Apr 19, 2008 7:49 am
PostPosted: Sat Apr 19, 2008 10:49 am
nice and clean. where did you find it? fleabay?
PostPosted: Sat Apr 19, 2008 1:05 pm
this is going to be one very interesting project best of luck with all mate :) car looks minty mint ;) 8-)
PostPosted: Sat Apr 19, 2008 1:27 pm
how mint! :shock:
good luck with the project 8-)
PostPosted: Sun Apr 27, 2008 10:07 pm
Some pics of what ive been up to today...
Discovered some good news today.The ecu pin setup for the 1.1 is the same as the Si so im really hoping i wont have to swap the entire interior loom :thumbsup:
Once the engines out id like to have a wash n scrub in the bay and give it a fresh coat of diamond white.
PostPosted: Sun Apr 27, 2008 10:17 pm
should come up nice once the bay is cleaned mate...good work keep it up :)
PostPosted: Mon Apr 28, 2008 12:05 am
Good to see it underway 8-)
With regards wiring, SMO on fiestaturbo did a similar conversion, putting an XR2 1.8 inbto a 1.1, might find a bit more info if you can dig his thread up, was quite comprehensive iirc.
