It is currently Sat Mar 07, 2026 1:16 am
Post new topic Reply to topic  [ 1140 posts ]  Go to page Previous  1 ... 47, 48, 49, 50, 51, 52, 53 ... 57  Next
PostPosted: Thu Nov 08, 2012 1:59 pm
It's not the end of the world, only a few hundred quid if that, so my "done" is just as close as it ever was. Smart arse :P
PostPosted: Thu Nov 08, 2012 2:18 pm
shit news ry :cry:
PostPosted: Thu Nov 08, 2012 2:20 pm
"only" a few hundred quid :lol:
PostPosted: Thu Nov 08, 2012 2:21 pm
not that much really in the world of modified cars - your dephaser pulley was £600 :P
PostPosted: Thu Nov 08, 2012 2:29 pm
:lol: wasn't just a pulley! was a full cambelt and aux belt kit and 4 hours labour too. lol that pulley was £150 on it own though :doh:
PostPosted: Thu Nov 08, 2012 2:31 pm
Agreed, you just have to look at it that way. :)
It's barely the end of the world. I've had both rear arches cut out, completely uprated every god damn suspension bush on my car and had an engine blow up, so I think I can handle this :lol:
PostPosted: Thu Nov 08, 2012 2:48 pm
want to go in this again when new turbo and map is done :D
PostPosted: Thu Nov 08, 2012 2:54 pm
Needs a cage and stuff now as well :)
PostPosted: Thu Nov 08, 2012 7:43 pm
bad news Ry but sure it will be even better with a new'n!
i hope a jan track sesh is sorted as my car should be done by then too! when in jan would it be do you reckon? start, middle or end lol?
PostPosted: Thu Nov 08, 2012 11:06 pm
Cheers guys. Wouldn't mind something that spooled up a little quicker and had more flow, but my 2.5" exhaust may make the potential gains a little futile. I'm going to have a chat with a few experts as ever.
I'm thinking end of Jan to be fair Ben. Start of Jan for Donny.
What does everyone thing of these Alloys by the way? (would want them refurbished of course..)
Wedsports TC05 alloy wheels. Staggered sizes, 15x6.5 +30 , and 15x7 +30. - 4.8kg a wheel.
PostPosted: Thu Nov 08, 2012 11:38 pm
you have a custom exhaust dont you Ry?
cool man, will work my arse off so im ready for then :) soon as a date is set ill be game as a badger!
i like them ry. will you have a lower profile tyre though? they seem rather chunky. what colour would you go for? lairy?
PostPosted: Thu Nov 08, 2012 11:46 pm
Yeah it's a 2.5" true mandrel bent system, but very quiet! I need to get a flow chart of it to see what it can work with.
I'd go for a dark bronze colour. I am actually bidding on some other 16" alloys as we speak though, as the plan is to respray my current 15"s and fit some semi-slicks.
PostPosted: Thu Nov 08, 2012 11:53 pm
you're car would look amazing with slightly wider wheels Ry so i hope you get either or. dark bronze sounds the tits.
im sure you will do your research and get good results. be done by end of jan hopefully :)
PostPosted: Thu Nov 08, 2012 11:57 pm
I've mostly focused on the mechanical side of things, and although everything is coming together, I want it to start looking the part as well, and not the shed it looks like on a day to day basis.
First stop, wheels. :)
PostPosted: Thu Nov 08, 2012 11:58 pm
They look quite similar to standard dc2 wheels!
PostPosted: Thu Nov 08, 2012 11:59 pm
i think it looks spot on Ry but then again people say that about mine but i know it doesnt lols! good luck
PostPosted: Fri Nov 09, 2012 12:02 am
Yeah they do. The Enkei wheels you posted up only came on 96 spec JDM tegs as they are 15" but 4 stud, the ones below are replica 96 wheels for 5 stud 98's and UKDM's. Probably made by "Sprint". They do suit it though. if it ain't broke. :)
PostPosted: Fri Nov 09, 2012 7:41 am
i like those wheels ry!
PostPosted: Sat Nov 10, 2012 10:53 pm
Woohoo, fixed the issues I was having.
It wasn't what I fully expected. 2 totally separate issues at the same time. There's a metal collar between the housing and turbine that was loose, so I tightened this up until there was no movement and thought the issue was solved. Went for a drive, less noise occurring but still a major problem somewhere as the knocking was terrible.
So jacked the car up, took the front wheels off and inspected all the bushings and bolts, and scarily all 3 of the bolts connecting the N/S Hardrace lower arm bush to the chassis were 1/3rd their way off!!! :O Re-tightened them to 89 NM/66 LBF-FT. I'll need to locktight them up methinks. Also found that my O/S Hardrace ARB boot has broken and they are less than a year old (in fact just over 6 months!) so awaiting for some new different aftermarket replacements for free.
Anyway, went for another drive it and it was perfect. No more rattles and much more responsive steering. Scary how that happened all of a sudden, as I'd only had my car professionally checked and geo'd a few months ago.
So hopefully all is well with the turbo after all :D
PostPosted: Sat Nov 10, 2012 10:59 pm
Glad the problems are sorted! It is mad how stuff like that can happen - with regards to the bolts. Deffo needs something on them to stop that happening again!
