It is currently Fri Mar 06, 2026 9:05 am
Post new topic Reply to topic  [ 1042 posts ]  Go to page Previous  1 ... 40, 41, 42, 43, 44, 45, 46 ... 53  Next
PostPosted: Sat Jul 28, 2012 8:04 pm
Well this just happened...
Funny story actually! Basically there was a load of annoying little flies on the windscreen while I was sitting on the inside of the car... I banged it to get them off aaaaaaaaaaand thats when it cracked. :doh:
Although you can't see it, it goes all the way down to the wiper too.
I'm mega pissed off at the moment.
PostPosted: Sat Jul 28, 2012 8:21 pm
ah not good> take it the fly took off then? and what did you mean on facebook when it said you were having more trouble?
TEAM AUBERGINE
PostPosted: Sat Jul 28, 2012 8:31 pm
Yeah the flys won the battle. Although they never came back, so thats good! :lol:
When did I put I was having more trouble with it? Can't think when I put that...
PostPosted: Sat Jul 28, 2012 11:15 pm
Iv done the exact same, surprising how easy they break lol. See if you can get a mk5 window bonded in.
PostPosted: Sun Jul 29, 2012 12:29 am
Can't be arsed with bonding a mk5 one in. Might as well just get a mk3 one and slip it in. It'll save loads of hassle.
PostPosted: Sun Jul 29, 2012 1:53 pm
Go electric!
PostPosted: Sun Jul 29, 2012 8:43 pm
Heated you mean? lol
I can pick one up for £50 with wiring, switch and relay ect... Worth it guys?
PostPosted: Sun Jul 29, 2012 9:46 pm
Not too bad a price if the screen itself is perfect (apart from a damn good clean). I got a no scratch screen from a scrappy and the loom for something like £30, but don't forget that was self removal!
PostPosted: Sun Jul 29, 2012 9:48 pm
But I should add that a heated screen is AWESOME. Just make sure your alternator is up to the job though. Mine screams in pain...
PostPosted: Sun Jul 29, 2012 10:20 pm
Well there is apparently a small chip in it, so i'll see how bad it is and if it is just really minor which you cant notice I'll probably get it. Mine had a couple of chips in it so meh. I'll haggle. My alternator is more than up for the job of a pissy heated screen lol
PostPosted: Sun Jul 29, 2012 11:43 pm
Famous last words before you stall it because it takes that much power!
PostPosted: Mon Jul 30, 2012 2:52 pm
30 amps isnt that much power, well compared to other things it is perhaps, but meh, I can run subs, heaters, rear screen de-mist and lights ect all at the same time with no problem so a front screen should be ok :lol: You might need to check the alternator and/or battery is working properly if it screams in pain.
Anyway, on a possitive note, I am getting a heated windscreen to replace mine at some point this week, so thats a bonus. I'll hopefully get that in by the weekend and I MIGHT be going to ford fair in this again now.
Just need to sort a few things out first :)
PostPosted: Tue Aug 07, 2012 11:11 am
Soooooooo, as you may have seen the windscreen lost a battle with myself :lol:
I went to Southampton to get another one as it was the closest one I could lay my hands on, plus, it's heated which is always a bonus! It came with the loom and what not too, but its from a mk3, which means I need to either get a mk3.5 loom or chop into the loom somewhere else and wire it in. For now I have left it so I dont piss anything else up just before ford fair :lol:
Anyway, this is the screen. It came with a boy racer sun strip - which was on there because it was a track car project.
Then I had to remove the old one. That was fucking hilarous! As I was breaking the seal nice and gently with a screwdriver it decided to crack on the other corner :lol:
Started with the one original crack...
And then it cracked on the other corner...
Aaaand then it ended up like this :lol: ....
Side by side:
No windscreen oooo...
Then I laid the new screen on to see what it would look like with the sun strip...
Then fitted it and removed the sun strip:
Made a random video of the cracks getting bigger and bigger while breaking the seal too :lol:
The reference about getting a professional to do it was about if you wanted to put the screen back in, because how people manage not to break it is a mystery after my attempt of removing it :lol:
PostPosted: Tue Aug 07, 2012 11:20 am
looks good ;)
i like the sun strip :(
PostPosted: Tue Aug 07, 2012 12:17 pm
Looking good. That sun strip almost worked didn't it?
From my experience with screens, if you want to keep it you should buy or source another rubber seal (maybe from a screen already broken in a scrappy) and then just cut off the existing one.
PostPosted: Tue Aug 07, 2012 12:19 pm
I did at first, but I took it for a quick drive up around the close to adjust the rear view mirror and it annoyed me in about 10 seconds. The visability is worse with it, plus it reflects my hands on the steering wheel so it kept catching my attention and annoying me. It is much deeper into the screen than you realise too!
PostPosted: Tue Aug 07, 2012 12:44 pm
:lol: fair enough ;)
PostPosted: Tue Aug 07, 2012 11:47 pm
whats that green cable up the pillar danny?
PostPosted: Wed Aug 08, 2012 12:15 am
Aerial cable
*edit, spelling.
Last edited by - Danny Boy - on Wed Aug 08, 2012 10:31 am, edited 1 time in total.
PostPosted: Wed Aug 08, 2012 12:17 am
why is it there lol?
