It is currently Sat Mar 07, 2026 9:47 pm
Post new topic Reply to topic  [ 1042 posts ]  Go to page Previous  1 ... 37, 38, 39, 40, 41, 42, 43 ... 53  Next
PostPosted: Wed Jun 13, 2012 6:16 pm
PostPosted: Wed Jun 13, 2012 9:26 pm
how are you going to set them up danny?
PostPosted: Wed Jun 13, 2012 10:02 pm
What I intend to do is whack the car on the laser alignment down at pro-tyre with the normal lower arms, get the tracking done as it's slightly out.
Then swap the arms over and get it done again.
Both print outs will give me a camber reading, so I know how much positive camber they give and see how close it is to standard. Then I might increase the hole sizes and shave some of the front lip off to give me more if I need to. Then go back again to see how much closer that is to standard.
I'll also be able to visually see how much difference there is when I change the arms over too. I will probably make them have even more camber adjustment at a later date. I expect it will need it. We will soon see though!
PostPosted: Thu Jun 14, 2012 8:08 am
looking good danny :thumbsup:
shame about the insurance but at least you'll have some time to carry out all the little bits and bobs you want to do :D
PostPosted: Thu Jun 14, 2012 9:06 am
awesome, sounds time consuming but still awesome. you not thought of using danfrasers method since it will be off the road?
PostPosted: Thu Jun 14, 2012 10:19 am
PostPosted: Thu Jun 14, 2012 3:02 pm
As you know, I have been making some camber adjustable lower arms.
These will pull the bottom of the wheel in by 5mm. So that's 5mm less negative camber essentially. In terms of how many degrees that is and how close that is to standard I am not too sure at the moment.
I will probably modify them more in the future to allow between 5-10mm of movement, but for now, these will do and will help prolong tyre wear on the inner edges slightly. Also I will replace the rubber bushes with polyurathane ones, or spherical bearings at a later date too.
A few pictures:
PostPosted: Sun Jun 17, 2012 6:33 pm
5mm won't be enough at your ride height.
How did you shave the holes? I was pikey and just shoved the grinder in.
I need to make some more cause it looks like ive bent one :lol:
PostPosted: Sun Jun 17, 2012 8:23 pm
I know, I'll fuck around giving them more adjustment later at some point.
I used a round file and a bit of elbow grease. The arm themselves didn't take too long, the ball joints did though because the metal is so thick!
Pot hole? lol
PostPosted: Sun Jun 17, 2012 8:28 pm
Danny, I might get some pieces of wood and create a device to measure camber :P
Should be fairly simple to knock up. Flat piece of wood a couple of feet on each side for the base, vertical 2x2 with a horizontal bolt for hinging another vertical piece with a spirit level built in. Another vertical piece on the same bolt is what sticks out and has the pieces to place against the alloy edges.
Hell, if I find the right pieces of metal it could be my first welding project :)
PostPosted: Sun Jun 17, 2012 9:40 pm
Go for it :)
Easier way: piece of wood + iphone app. Sorted :D
http://www.bimmerfest.com/forums/showth ... p?t=325556
PostPosted: Sun Jun 17, 2012 11:02 pm
iPhone isn't quite accurate especially if the phone is warm. But nice thinking :)
PostPosted: Sun Jun 17, 2012 11:14 pm
What proof do you have to back that up then?
PostPosted: Mon Jun 18, 2012 12:33 am
Because I experience it with mine :P
PostPosted: Mon Jun 18, 2012 9:12 am
I've never had any problems with mine in all the time I've been using the acceleromter on the phone. But then I don't let my phone get hot, the only time it does get hot is if I play a game for an hour or two which requires the phone to work to the max.
But once the app is caliberated up properly it's quite accurate from testing I have done with it. I'm not saying it's perfect because it wont be, but for a rough idea of the reading you can't really go wrong :)
PostPosted: Thu Jun 21, 2012 3:41 pm
Basically over the last few days I have been busy! I don't have pictures of everything because I just wanted to get through it all. I will focus on a few things below in the update.
This is the list of stuff I have done!
Rust hunting/ Smashing the fuck out of bits with a hammer and screwdriver. No holes made. So under side is solid still. Win.
Got rid of scabby surfact rust/bubbling paint on front panel. Then undersealed it.
Re-undersealed the whole under side of the car - inside the arches to do another day.
Stripped down front suspension for a clean up and inspection.
Greased up all the poly bushes at the front as there is a annoying as fucking squeeking noise.
Changed lower arms for camber adjustable ones.
Fucked a lower arm pinch bolt.
Temp adjustment on tracking.
General check of bolts here and there for the sake of it.
Made a shitty cold air feed to help combat heat soak.
Replaced lower arm pinch bolt.
Fitted standard crossover pipe and whacked the K&N on it.
Broke a gearbox mount.
Later this weeks jobs are:
Strip down and clean rear suspension.
Paint/underseal all the arches.
General clean up of the engine bay.
Give it a service - plugs, oil, filter ect.
Replace gearbox mount.
Clean header tank.
I think thats it.
Lower arms:
So, the lower arms! I fitted them the other day. I had a problem where I stripped the thread of the pinch bolt, so had to pop to ford to get a couple of new ones, only cost £4.82 for both.
Test drove the car today, it was sunny at one part and raining the next so it had a good overall test. Now they have less camber, it make a difference to traction in the wet for sure!
Before hand where the wheels would be running on the inside of the tyre they would just spin up all the time and loose grip around corners, now I can floor it everywhere and the tyres grip!
So that's a possitive mod!
Also visually the camber has decreased slightly too.
Few pictures of them on the car.
Rust hunting and Undersealing:
So I do this once a year. Go on a massive rust hunt, see if I can make any holes ect. I didn't go easy. Two tools: hammer + sharp screwdriver. I looked under the car and saw the underseal from last year was still intact, so that was already a positive sign, But I still went poking for holes. I made none. So thats good!
The front valance had a bit of scabby surfact rust on it from where I quickly sprayed it last year and it had oxidized (sp) under the paint. So I scraped that off and undersealed that and then did the rest of the underside of the car too.
I will do all of the arches later this week.
Standard crossover pipe.
Now before some of you fuckers say "I told you so"... I know you did :lol: I wish I had listened!
Jay sent me a crossover pipe which I put on the car after a quick clean up. It makes so much difference! There is more power and more torque now. I wish I did this sooner rather than fuck around. I kinda like the look of it now I'm used to it too. So thats always good.
On a down side, because it now has 1 million torques (as Jeremy Clarkson would say) I launched it a bit too hard down a road and broke a gearbox mount. Fail. So that will be sorted later this week.
The header tank is going to get a good clean don't worry. And I'm going to sort out the intake > maf piping soon with some silicone or something.
Other bits I have done.
I had an annoying squeek coming from the front over bumps ect. So I decided to see if it was an anti-roll bar bush. So I took them out and lubed them up, while I was there I did the top mount polys and stripped down the front suspension for a general clean up being coilovers. I will be doing the same with the rears too.
I think thats it for the update. Not a lot in pictures. But meh. :lol:
Comments welcome as always.
PostPosted: Thu Jun 21, 2012 3:55 pm
nice work danny ;)
jony will love the crossover :P
PostPosted: Thu Jun 21, 2012 4:03 pm
Good work danny :thumbsup:
PostPosted: Thu Jun 21, 2012 4:37 pm
Looks good. How did you get the suspension off?? I can never get the top nuts off :(
PostPosted: Thu Jun 21, 2012 4:44 pm
