It is currently Sun Mar 08, 2026 6:59 am
Post new topic Reply to topic  [ 1140 posts ]  Go to page Previous  1 ... 33, 34, 35, 36, 37, 38, 39 ... 57  Next
PostPosted: Mon Nov 21, 2011 2:08 pm
Okie dokie mate. When are you planning on all this? Bleeding is a piece of piss, and even better with 2 peoples :)
I'm hoping mine goes through without too much work needed. It's just the emissions I'm worried about as it's overfuelling a bit at the mo...
PostPosted: Mon Nov 21, 2011 2:31 pm
I'm free next Sat and potentially Sunday. I might be able to get away with doing it on my own but will let you know :)
My lower engine mount moves so much it's insane now I have a harsher clutch engagement. The bolt hasn't moved, but it's on its last legs and it's causing wheel hop. Even with uprated "inserts" to stiffen it up from earlier in the year :lol: I'm going to see if Matt can work his magic touch on that with me.
PostPosted: Tue Nov 22, 2011 12:16 am
Will your car be this fast Ry? Im addicted to turbo'd honda's at the moment, last 3 days ive been watching soooooooooo many videos of them!
PostPosted: Tue Nov 22, 2011 2:59 am
that video is bollocks, 62-100 in less than a second... no
the cars probably on axle stands or at best a rolling road
PostPosted: Tue Nov 22, 2011 7:20 am
er i think it is possible :lol:
PostPosted: Tue Nov 22, 2011 8:59 am
That's in KM/H! But no, it won't be that fast :lol:
PostPosted: Tue Nov 22, 2011 9:12 am
I have to say I'd consider the same car and setup as Ry's in the future! :)
PostPosted: Tue Nov 22, 2011 11:47 am
PostPosted: Tue Nov 22, 2011 1:53 pm
Thanks guys!
It is a really good setup I think. I'd guess anything with high compression and a low-boost turbo setup is hard to dislike as a road car. Will update with pictures of my uprated poly engine mount later. Did it last night, and quite pleased with how dang easy it was :lol: :D
PostPosted: Tue Nov 22, 2011 2:20 pm
Ooooo very curious!
PostPosted: Tue Nov 22, 2011 2:26 pm
I've not cut out my original mould of the mount as it was brand new, I've just filled in the holes to strengthen it up! I'll be doing the same to my others as well, one at a time.
Will be interested to see what it's like to say the GrPN mount I fitted to the GTi-6 as that had serious gearbox and engine vibrations intruding into the cabin. I liked it though.
PostPosted: Tue Nov 22, 2011 2:43 pm
I need to do the gearbox mounts on the si, and as they are a simple rectangle with 2 bolts in, would be easy to make instead of paying for new decent ones :lol:
PostPosted: Tue Nov 22, 2011 3:17 pm
Yeah, I simply used parcel tape on one side of the mount, flipped it around and filled it in with poly, and let it set. This type of poly is designed so that you don'ty get any air bubbles trapped in it whilst it sets, which can happen when using cheaper and lesser strength stuff like sikaflex or tigerseal.
PostPosted: Tue Nov 22, 2011 4:53 pm
PostPosted: Tue Nov 22, 2011 7:40 pm
That's one of the earlier models before mine. There were a few variations :)
Getting to that kind of power isn't too hard though based on the video you've posted. an extra £1500 worth of parts and work on my build will ensure I can achieve a safe 500bhp. But I'd need a different turbo, drive shafts would probably need uprating, brakes, wheels and tyres, and it would be more for the high gears. 1st and 2nd gear are more than enough for the road at 8 PSI, however this cars strength is in gear, not from a standing start.
The key is to know your limits with cars. 14 PSI from 3rd to 5th will be enough for me on standard internals at this comp ratio. I'm going to focus on suspension and geometry next as this will eventually become a track day focused car in the next year or two.
PostPosted: Tue Nov 22, 2011 8:14 pm
Excuse the shoddy pictures from my phone!
Standard rear engine mount:
Mix-up a little bit from both tubs of poly to a 1:1 weight ratio and pour into spare gaps:
Leave it to set for a few hours, an voilà!
This is the exact stuff I used - It's a 70a shore hardness rating.
Very easy to make and pour in. Now it's set, it's very, very tough stuff. I left the mount as it was as it was a brand new one anyway, so a little extra won't hurt. My other two will get the same treatment as well as I have enough for them :chill: Much better stuff than Sikaflex/tigerseal. The bubbles simply pop when pouring so you don't get any trapped air pockets. It starts to become tough after 5 minutes so you need to be quick!
PostPosted: Tue Nov 22, 2011 8:19 pm
haha cool :D
oh thats the one, the dc1 looks sooo old now
PostPosted: Tue Nov 22, 2011 8:23 pm
I don't understand that stuff now..
So are you covering the old mount in poly? Or making a new one out of poly with the old one as a template? :D
PostPosted: Tue Nov 22, 2011 8:29 pm
PostPosted: Tue Nov 22, 2011 8:45 pm
So it's more to strenghten worn bushes than to make new ones out of like I was thinking then? :lol:
