It is currently Sun Mar 08, 2026 11:54 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1145 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 58  Next
 Post subject: Re: Paul's 2.0ltr Si
PostPosted: Thu Dec 29, 2011 1:02 pm
Mapping without a wideband is asking for trouble anyway :lol:
I will be mapping the current engine with megasquirt and wideband so in theory the ZT lump will fire up on that map, then all I need to do is make adjustments to make it within tolerable air/fuel ratios.
Before the ZT goes in, I want to get the current lump RR'd on standard ECU and then on Megasquirt to see how much difference it makes. Standard 2.0ltr on megasquirt push out 140bhp.
PostPosted: Thu Dec 29, 2011 11:54 pm
Heres some insight into Turbo builds. Friend came up with it and its epic.
You can only choose two:
Cheap
Reliable
Fast
Can't wait to see how it all turns out, i'll look into it over time and might whack a blacktop turbo in in 2013, or sooner if it goes bang AGAIN
PostPosted: Fri Dec 30, 2011 12:57 am
Mine will be reliable because I'll be anal on the cooling systems for oil and water, and making sure I don't go overboard with boost. Proper engine heating and cooling before and after a journey etc.
I'm toying with an electric water pump, I was going to get one on the ka project... they pump the water speed vs temperature not at rpm, so for example.. you slow at a junction it will keep pumping fast vs a normal water pump which will slow to rpm idle speed. Which on a zetec is handy IMO!
Was also toying with an electric pas pump, but tbh no need. Just me being fancy.
I'm looking forward to it, but I've got a long way yet.
Bodywork
Intake trumpets
Squirt on na
Wideband on na
Oil cooler system
Gauges for oil temp, oil pressure, water pressure, volts, and boost ready in position.
Then build the engine, then one weekend of fitting. Lol
PostPosted: Fri Dec 30, 2011 3:53 am
140 on MS is pretty good over standard, in a fiesta it be about 128 on a deep etc
PostPosted: Fri Dec 30, 2011 7:11 am
But I never trust figures anyway, so I'm gonna get it RR'd on standard ECU and then MS afterward to show the difference.
Will have wideband plugged into the RR too to show my fuel/air ratio.
PostPosted: Fri Dec 30, 2011 9:43 am
Deep, desk and dewy ecu's are meant to give you 136bhp, that 128bhp figure can be down to all sorts of other resrictive things, not the ecu j-boy
PostPosted: Fri Dec 30, 2011 1:07 pm
136ps - 134.13951562bhp to be technical. Then factor in losses and the fact no engine is as good as they say.
PostPosted: Fri Dec 30, 2011 1:12 pm
alright smart arse! lol
PostPosted: Fri Dec 30, 2011 1:19 pm
Im at work, bored :lol:
PostPosted: Fri Dec 30, 2011 1:58 pm
http://www.reddit.com
that should keep you going for a while
PostPosted: Fri Dec 30, 2011 8:45 pm
http://www.9gag.com shall do better :D
most people rolling road them standard after dropping it in a fiesta get 126-130 horsies, but yea depends on so many things!
mainly the exhausts fault
PostPosted: Fri Dec 30, 2011 8:52 pm
9gag is literally just stuff that gets posted on reddit months ago lol
PostPosted: Fri Dec 30, 2011 8:58 pm
good thing i dont go on reddit then aint it
PostPosted: Fri Dec 30, 2011 9:05 pm
130bhp is for pussies :lol:
Roll on 200 horses. Then my fiesta plans are complete and I can get another ka.
PostPosted: Fri Dec 30, 2011 9:38 pm
noo 130 is awesome! :D
(not biased at all! obviously...)
nah fuck aye, 230bhp with chatter = my dream :D
consider your poor tyres paul!
PostPosted: Fri Dec 30, 2011 10:16 pm
Tyres can fuck themselves.
Will be running 888s when the Turbo is in.
Dunno if I could safely stretch to 230bhp, but I'm going for 14psi now instead of 10.
200 easy.
PostPosted: Fri Dec 30, 2011 10:39 pm
200bhp easily with that, may even get 230bhp easily, maybe more! the airtec/auto specialist/devil development fiesta puts out something like 260 odd on 13psi, pretty sure thats a zetec. cant remember, might be completely different setup mind, but 200-230 is probably easy to get :)
PostPosted: Sat Dec 31, 2011 2:01 am
I don't want to push it to its limits being a Decomp setup, so I'm happy to hit the 200 barrier.
Soon as I affect reliability it'll be a ballache.
Hopefully my cooling systems will keep it all fine and dandy, specially the water pump setup :)
PostPosted: Sat Dec 31, 2011 10:44 am
Yeah I can see where you are coming from, it should good when its done.
I just thought about the water pump, put some sort of LED in the dash so you know its still on and pumping, you dont want to have an electronic fault with it and to do over the engine lol
PostPosted: Sat Dec 31, 2011 8:03 pm
Good point.. I will be getting a controller for it as well so I can adjust the pump, like for on track it something.
Don't neeeeed that pump but tbh it.will make life better!
