It is currently Mon Mar 09, 2026 7:12 am
Post new topic Reply to topic  [ 1042 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25 ... 53  Next
PostPosted: Sun Dec 18, 2011 9:30 pm
Shed.
PostPosted: Sun Dec 18, 2011 9:41 pm
Yep it sure is!
PostPosted: Sun Dec 18, 2011 9:58 pm
Bit of good news, a friend off fiestaturbo forum said I can borrow his engine crane, so im going to properly crack on with the new engine now getting it all painted and that, and then hopefully fit it around new year time.
Still need a few bits for it, hopefully xmas money might cover the cost of them bits.
So soon, I should have a nice 2 litre engine in the car. Just need to read up about all the PATS shit and what not, and other little bits for the conversion although most is already done from what I can remember.
SLIGHT JOY OF RELIEF!
PostPosted: Sun Dec 18, 2011 10:16 pm
you have literally nothing to worry about with PATS, nothing at all, mk3s have it build into the car itself, NOT the ECU, so you can use any ecu on the car (deep desk dewy etc) and it will work fine
edis is a issue, needs to be deep or a name like that :)
PostPosted: Sun Dec 18, 2011 10:45 pm
Thats what I was thinking. Well thats good then :)
I miiiiiiiiight have a runaround to while my car is off the road... im going jap! :D HONDA! 2 litre.... mwahaha.
Its only a fourth generation prelude in silver, cant remember what spec/model it is, but its only an auto-spastic, so its nothing special. Its actually nans runaround... she drives a lotus elise usually lol.
PostPosted: Mon Dec 19, 2011 12:32 am
Epic.
PostPosted: Mon Dec 19, 2011 2:03 am
Epic gran is EPIC!
PostPosted: Thu Dec 22, 2011 9:48 pm
Small update
Fiesta still runs - its a mircle :lol: Oil and water are mixing LOVELY at the moment, uses so much water too lol.
Tomorrow it shall be coming off the road until the new year/some point in January for an engine transplant, yup, the 2.0 mondeo engine will be going in. Christmas money will be spent on parts for the engine, I may not have all the parts that are needed first of all, but I will get them all eventually. Vital things like cambelt and water pump and possibly clutch will be changed while the engine is out of the car - saves hassle later down the line and also breakage of the engine too.
Other things like HO/RS1800 inlet and throttle body can be found later on, I currently have a 1.8 escort GTI inlet and throttle body which I shall use temporarily until better is found - both came with the engine as it was in an escort gti before and the guy who had it used them both and said it still flew, I have a 1.8 MAF sensor and also the actual sensor part from a deep/desk/dewy 2 litre mondeo - not sure which one but I have it, so may use that when the ECU is changed to see if it runs ok seeing as the 1.8 and 2.0 maf housings are the same (I think), the ECU is something else I need, so I am still on the hunt for one of them. So, will hopefully find one before the fiesta is back on the road.
So while the fiesta is off the road, I will have a temporary run around, its japanese, its a honda, its a fourth gen 2.0 prelude. Its my nans run around so I am going to borrow it while the fiesta is getting a new heart and she can just use her merc lol.
Update complete, I think! lol
PostPosted: Wed Jan 04, 2012 7:13 am
crack on :)
PostPosted: Wed Jan 04, 2012 12:57 pm
I do need to, but waiting for parts to come.
I have on order:
Cambelt kit
Clutch kit
Water pump
Drive belt
CVH oil filter
ST150 brake pads
Spark plugs
Then other parts im waiting to get from someone are:
HO inlet
2 litre throttle body
2 litre MAF sensor
Dewy ECU
Bit of paint here and there, and it will be in. Prob wont be until next week or maybe the week after now due to a couple of things, but its all good. This engine still drives so its not doing too badly :lol:
PostPosted: Wed Jan 04, 2012 1:35 pm
Have a week off next week so if the car is ready I can help :)
PostPosted: Wed Jan 04, 2012 4:09 pm
Depends when all the stuff comes too, Im waiting to send some money to Funkynut on here for inlet ect, but hopefully it should all be done soonish :) Need to paint the engine yet, might have to crack on with that later this week!
PostPosted: Wed Jan 04, 2012 8:23 pm
Excellent stuff, now hurry up lol
PostPosted: Mon Jan 09, 2012 2:46 pm
I need this shiz
fiesta si 1.6 water pump, flywheel, sump + oil pick up pipe, efi inlet manifold, exhaust manifold
So store it all somewhere so I can have it one day :) although some of it i might want to get brand new lol
PostPosted: Mon Jan 09, 2012 4:14 pm
What do you need all that for? lol
PostPosted: Mon Jan 09, 2012 6:33 pm
Turbo y0!
PostPosted: Mon Jan 09, 2012 7:25 pm
but it wont fit on the zs you mellon
PostPosted: Mon Jan 09, 2012 7:26 pm
Of course it won't bell end. :doh:
PostPosted: Wed Jan 11, 2012 9:27 pm
Sup guys, small update on the engine.
Over the last few days I've decided to crack on with the engine, making it look fresh and new ready for the swap and renewing some bits on it.
So before it got stripped down, it looked like this if you cant remember: viewtopic.php?f=5&t=18685&start=340#p294062
There are still a few bits to come; HO/RS1800 inlet, 2.0 throttle body, 2.0 maf and 2.0 ecu. These are being sent out next week thanks to Funkynut. Once they are here, I will clean them up and spray them silver. Bits to be sprayed are; inlet, throttle body, injector rail, maf, rocker cover and a few other bits. Going to do it as one bulk lot to make the most of the spray cans.
The other day I got this lot:
- CVH Bosch oil filter
- Circoli water pump
- Pagid ST150 brake pads
- Continental contitech cambelt kit
- Continental contitech drive belt
- Valeo clutch kit
Today I picked up a few gaskets and spark plugs.
Then cracked on.
Engine stripped down
Sump wire brushed, block and head cleaned of any grease
Block painted black
Head and sump painted silver, and dipstick tube
Exhaust manifold painted
Cam pulleys painted silver
Cambelt off
Water pump off
New water pump vs old
New water pump fitted
New cambelt kit fitted
New oil filter, engine filled with new oil too
Back of engine painted
Going back together
Result of engine painted
Crankcase breather painted and fitted
Exhaust manifold fitted
I will update this again when the other bits turn up and are painted :)
Engine should be goin in next week at some point :thumbsup:
PostPosted: Wed Jan 11, 2012 11:04 pm
ugh posted on FT instead of here...
well anyway looks good :D
Users browsing this forum: Google [Bot] and 47 guests
