Fiesta-Si.com • View topic - To the death hopes and dreams
It is currently Fri Mar 06, 2026 4:09 am
Post new topic Reply to topic  [ 316 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 16  Next
PostPosted: Mon Oct 10, 2011 11:13 pm
yea true, it was the looks i was referring too, mine looked too chunky with 50s
PostPosted: Mon Oct 10, 2011 11:18 pm
I won't mind these too much, the 60's I currently have just look... wrong.
PostPosted: Tue Oct 11, 2011 10:30 am
60s are bigger than the world lol
45s are perfect for lowered but 50s will fill the gap better when standard height.
PostPosted: Tue Oct 11, 2011 7:49 pm
Everything is on now. Car runs a dream with the new system on, smooth power and in heavy traffic I got a hint of more power lurking in there above 3.5k. The old system stuffed it after 4k and felt worse than my old 1.3. Going to give it a blast in a bit just to see what is there above 4k now.
The new tyres and wheels look awesome. The car looks like it sits about a foot lower!
Need to inspect the tracking and toe alignment as it's a little 'higgledypiggledy' over non-smooth surfaces with quite a surprising pull either side if the surface is bad. Some of this may come with the additional torque from the new exhaust but it's more than that. Checked the bushes on the wishbones and other suspension parts I can quickly see and they look fine, so need to take measurements to make sure.
PostPosted: Tue Oct 11, 2011 9:41 pm
PostPosted: Tue Oct 11, 2011 9:46 pm
LOL! Quite true about the MK3.
PostPosted: Thu Oct 13, 2011 10:47 am
whats tramlining?
zetecs come to life atfer 4k mate :D
even the 1.6 will give a nice kick after 4k :P
PostPosted: Thu Oct 13, 2011 11:12 am
http://www.tirerack.com/tires/tiretech/ ... ?techid=47
The first paragraph sums it up nicely. Bad tracking (or toe angles) can cause the reverse to happen, ie. instead of grooves, raised areas along the direction of travel cause the car to want to veer off. This is usually caused by idiots doing your tracking and not realising the back wheels aren't actually straight like they think they are. Because the fiesta mk3 (and countless other cars) have a toe out on the rear, this causes the laser guided tracking to be well, wrong. Unless they REALLY know their maths to account for the discrepancy. Which is unlikely because everyone who's done tracking for me have been dribbling idiots.
PostPosted: Thu Oct 13, 2011 11:14 am
Oh and i couldn't try the 4k test because the car is scary as hell with the toe out issue! Makes the car act like a Focus RS500 with the torqwue steer.
PostPosted: Thu Oct 13, 2011 6:05 pm
Got the bits set up for tracking the car myself. Using the string and bars method outlined by heeman10 on ft.com. Got it all squared up and confirmed the measurements 3 times and it was spot on for positioning, so started measuring up the front tracking. It was 15mm toe out. The ideal amount is 6mm +/- 3mm, so I was already 6mm over the maximum tolerance. This well and truly explains the issues I've been having! I was aiming to get 2-4mm toe out in total to keep the toe out setting but get the car nice and stable on straight driving. After some experimentation and adjusting I reached a figure of 4mm toe out but this still causes some pulling issues under braking and surface conditions. I think that maybe I need to hit 0-2mm to account for the method I'm using and also adjust the rods to return the steering wheel to centre.
PostPosted: Fri Oct 14, 2011 4:08 am
hmmm didnt see james' tracking method works i take it?
lol at massive tracking faults, i went through 3 tyres coz i was lazy and cheap, hardly worth it... (part worns)
PostPosted: Fri Oct 14, 2011 9:54 am
PostPosted: Fri Oct 14, 2011 2:10 pm
Ooooooh! Pretty pictures! Haven't done these in a while, but took a few while I was doing the tracking. Had a second go at the tracking to improve it as it wasn't quite right still and I have a new and quite quick method now. I'll write it as a guide as that shows exactly what I did.
Firstly, doing the tracking yourself requires a flat surface for the car to be on however there's no such thing as flat in Derby, so I chose a slight slope and aimed for 1mm toe out max. The reason for this is when you edge a car forward up a slope (FWD anyway) the front wheels will pull the car forward and hence toe in compared to the normal setting. It isn't much but it's something to consider when doing the calculations.
To follow this guide you will need:
Two axle stands.
Sliding caliper ruler.
Whatever tools you need to remove the wheel caps.
Spanner sized for the tie rod end locking nut. (Fiesta MK3's are 19mm).
Mole grips.
Cloth.
Knife/scissors.
String.
Pen and Paper.
You will also need something to go under the front wheels to allow them to turn easily. I used two large pieces of cardboard and four sheets of magazine cover (mine here was the cover pages from F1 Racing magazine). All you need to do is break the friction between the road surface and the tyre. Place these just in front of the wheels and gently edge the car onto them, checking to see if they are correctly positioned as so:
Make sure the wheel is now centred and remove the keys to lock the wheel with the steering lock mechanism.
Next, take your axle stands and position them fore and aft of the wheels on one side. Measure the height of the centre of your wheel and find the best point to run the string on your stands. My wheel centre was about 28cm, and this pretty much lined up with the bolt hole on the axle stands. To make sure my tying didn't offset the string, I tied the string on one hole then passed it through the other side towards the other stand. Move the stands until they are starting to tip towards the other one and this should be nice and taught. Move them closer and get the string about an inch away from the wheel edges front and back, no need to be accurate, more adjustments coming.
Take the caps off the wheels. and get the sliding caliper tool out. I got mine from a pound shop (!) and it's the rod part we want to use as so:
Do this on both wheels, measuring both sides, then move the stands to equalise them out. Use dead reckoning, ie. aim for about 30mm on all measurements, the toe angles front and rear, along with the track distances will give plenty of room for 1-2mm error here, though the more accurate you make it the better. Once equalised you can now start measuring the front toe. Shake the car a little, bounce the wheel up and down to make sure first. Measure the foremost point on the wheel, and the rearmost:
Shake and bounce the car again, measure again. On the pen and paper I named the front edge A and the rear edge B. Add the two measurements together, as we did two measurement, the first front measurement is A1 and the second after the shake is A2, B is the same. Add them and divide by 2. We now have a more accurate number to work with.
Now A needs to equal B-3mm (+/-1.5mm). This is based off the official Ford figures for toe angle and converted for 15inch wheels, these figures would actually be in the acceptable range of all Fiesta models. However, if you did it on an up slope like I did, you will need to account for the pull on the toe when edging forward, which means you want to aim for a zero toe or a A = B-1mm amount. This is what I went for. My A was 15 and B was 21, a difference of 6mm after taking two measurements! Well outside the tolerances, but from what I did yesterday I knew this was an improvement!
Now, one turn on the tie rod equals an adjustment of 1mm (ISO thread measurements). You need to take your difference and divide by two. This is the number of turns you need. Get under the wheel, don't disturb the string, and loosen that tie rod end locking nut one more turn than what you need. Take some mole grips and the cloth and turn that tie rod. I needed 3 turns anti-clockwise to move the tie rod out of the tie rod end to adjust for 6mm difference. I wasn't going to mess about with half a turn to hit 1mm toe out. Preferably, use something on the tie rod to help count your turns, I use a zip tie. Adjust accordingly and then tighten the tie rod end locking nut. Shake and bounce the car and remeasure. Repeat until you're happy with the numbers.
Do the same for the other side.
Here's the maths:
A1 - 14
A2 - 16
B1 - 20
B2 - 21
A3= A1 + A2 / 2
B3 = B1 + B2 / 2
B3 - A3 = DIFFERENCE
If DIFFERENCE is positive, tie rod turns are anti-clockwise, else clockwise. TURNS = DIFFERENCE / 2
I am never going to pay someone to do my tracking ever again. I went for zero to 1mm toe out, drives perfectly now. Still a little ever so slight pull here and there, so I may retrack at some point and move it in a mm more.
PostPosted: Fri Oct 14, 2011 5:56 pm
christ is all i can say :P awesome man, well done
PostPosted: Sat Oct 15, 2011 11:41 am
sorry mate i lost the will to live halfway through that, not worth the effort of £25 lol to just go to a reputable garage :P
plus i hate maths
PostPosted: Sat Oct 15, 2011 12:29 pm
PostPosted: Sun Oct 16, 2011 2:47 am
haha silly texts :P video be more direct imo :D
PostPosted: Sun Oct 16, 2011 8:48 am
I'll see what I can do, lol.
PostPosted: Sun Oct 16, 2011 6:49 pm
lol no not on my account, was just saying its more a video sorta explaination to get that across, or in person
PostPosted: Sun Oct 23, 2011 2:03 pm
I've been researching the number 12 mod, wiring in a line feed directly into the radio. Turns out Ford scrubbed the IC numbers and put their own codes on. I've trawled through so many Russian forums I could probably speak it. The main thing to find is the pre-amp from the tape cassette, once these have been found I will intercept the outputs from this and wire in the input, drill a hole into the case for an input jack (so it's easier to unplug the radio) and put it all back together.
