Fiesta-Si.com • View topic - Saph cossie. Breaking, Pg70 13.04.14
It is currently Sat Mar 07, 2026 1:00 am
Post new topic Reply to topic  [ 1410 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 71  Next
PostPosted: Wed Jan 06, 2010 8:50 pm
Onslack's other half
all this touching going on, you bunch of pervs :D back to car talk
PostPosted: Fri Jan 08, 2010 1:40 am
PostPosted: Fri Jan 08, 2010 3:04 pm
im not jealous, honest. im not. :hmm:
PostPosted: Fri Jan 08, 2010 5:24 pm
Alex my sweet pea, don't suppose you've got a spare Fuel pump, or know of one going cheap. Need one to run with the swirl pot set up. :)
PostPosted: Fri Jan 08, 2010 9:28 pm
I cant say i do im afraid Matt.
I may end up getting rid of the one i have at the moment if i get a new setup. But its all ifs and buts at the mo
Its known as a 044 bosch pump. 200L/ph @ 5bar
Where did you get you swirl pot from ?
PostPosted: Fri Jan 08, 2010 9:44 pm
It's one of these ones (Good old chinese) :lol:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Had to go for a square one as im limited for space in the already cramped engine bay, if i put it in the boot id have had to build a firewall box around it. :(
Standard one will be fine for my use, its flowing enough for your 400bhp and i want less than that so im sure will be ok. :chill: If you know off any going for cheap etc on PF or likewise give me a shout. :halo:
PostPosted: Sat Jan 09, 2010 5:49 pm
That doesnt look too bad for the price realy... The TIG welding is pretty tidy.
The standard pump is good for 350-375bhp on a saph and they can be picked up pretty cheaply on ebay quite often. I will keep my eyes open though ;)
PostPosted: Wed Jan 13, 2010 8:29 pm
More goodies
Double Valve Springs
Wasted Spark driver and some fancy plugs
New set of genuine lifters/tappets/followers ( what ever you feel like calling them today )
also got a recon alternator cheap with only a few miles on it
PostPosted: Wed Jan 13, 2010 8:48 pm
oooh yes, time too get this show rolling :D
where be your cam at? :hmm:
PostPosted: Wed Jan 13, 2010 8:54 pm
looking good :) more bits ftw :)
PostPosted: Wed Jan 13, 2010 10:45 pm
oooooooooo, they look good mate! :chill:
PostPosted: Wed Jan 13, 2010 11:44 pm
PostPosted: Thu Jan 14, 2010 9:25 pm
Another thing camein the post for me today.
This time in the form of a camcover gasket and half moon seals
PostPosted: Thu Jan 14, 2010 9:35 pm
let the fun begin :chill:
PostPosted: Thu Jan 14, 2010 10:34 pm
Just had an email..... bolts been despatched today
PostPosted: Thu Jan 14, 2010 10:36 pm
thats awesome buddy :thumbsup:
lets hope the rain holds off.......
you get my text....if yes reply god damn you!! :P :D
PostPosted: Fri Jan 15, 2010 10:06 am
i take it the wasted spark driver board is internal to the ecu and you have to solder the wires into the board or do they go into the loom?....looking good on the update front
so is it a case of when your cam or cams arrive youll be slinging it back together ready for all the glorious weather were going to have :lol: ....or not as the case may be
PostPosted: Sat Jan 16, 2010 11:34 am
Hi Jam,
The wasted spark driver gets soldered into the ecu. Its abit tricky as the ecu was made 20odd years ago so the solder bath that was used would of been leaded, where as most solder these days has to be RoHS compliant and lead free so can make soldering the two togeth abit tricky sometimes.
When the cams turn up, thats jus the beginning.
Ive got to get the car MOT'd in the next couple of months, then the head comes off for some major porting and polishing, double valve springs fitting then tappets and cams.
Fit my new inlet, fuel system, and try and figure out why one of my pulleys has cut thro a hose.
Then remove gearbox and fit new one, off comes flywheel for a lighten and balanace. refit with new clutch, Fit hyd clutch conversion.
then its up for a live map etc.
And amongst all of the above, i need to source a decent front diff, a complete 2wd rear end and some decent brakes.
Dont expect to see the car again this year :(
PostPosted: Sat Jan 16, 2010 8:29 pm
More parts
New wideband lambda as the antilag killed the last one
Recon alternator ,cam cover gasket and half moons
PostPosted: Sat Jan 16, 2010 10:33 pm
nice bed sheets :lol:
was it the excess fuel that wanked the wideband or was it the extreme heat?! :P
