Fiesta-Si.com • View topic - 29/07/2013 the end of the line....
It is currently Sat Mar 07, 2026 8:08 am
Post new topic Reply to topic  [ 741 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 38  Next
PostPosted: Sun Mar 18, 2012 8:19 pm
TEAM AUBERGINE
PostPosted: Mon Mar 19, 2012 10:27 pm
whats happening on the back bud? brill progress! u a mechanic by trade sam?
PostPosted: Tue Mar 20, 2012 12:01 am
TEAM AUBERGINE
PostPosted: Tue Mar 20, 2012 12:03 am
p.s finaly managed to sort it so i got a matching track rod end now lol took some time it that motor factors though! :lolz: fitted now. and new high tensal bolts for the front arb.
TEAM AUBERGINE
PostPosted: Tue Mar 20, 2012 12:15 am
christ, well done for being honest! tossers.
sweet man... looking foward to the progress.
PostPosted: Tue Mar 20, 2012 8:49 pm
today;
the sacrifice of doing up a motor consistently; (my bed room)
mock up of my alloys; (cheers again specky for that deal!)
rear;
shocks off
TEAM AUBERGINE
PostPosted: Tue Mar 20, 2012 10:25 pm
polly arb bushes fitted.
TEAM AUBERGINE
PostPosted: Wed Mar 21, 2012 11:39 pm
right today went to fit the rear polly bushes in the top hats....
wasn't all that im pressed. they fit the srings good and the hat. no play up and down but plenty of play side to side. flo-flex seemed to have made the bushes not as wide as the origional ford one. if i put them in the top hat and push the shock to front of hat, theres about 1inch or so of movement (gap) so i did this. (see if you can follow, if not ask and ill explain);
put polly bush on top of oem rubber bush (see what i mean by width difference!)
and draw round
cut the internal out of the gen ford rubber.
so the polly can sit inside.
glue the oem rubber bush.... er well.... now a sleeve actualy.... into the top cap. fit the plolly bush into the spring and put the polly bush back in the genuine rubber sleave bush. so now the polly bush takes the weight/flex. and the oem rubber take the side to side wobble.
well theres only one way to see if it'll work.....
TEAM AUBERGINE
PostPosted: Thu Mar 22, 2012 7:37 pm
braided brake lines on and plastic arch liners in.
one of the rear hubs off. other one will be taken off tomorow,
TEAM AUBERGINE
PostPosted: Thu Mar 22, 2012 8:26 pm
Looking good Sam!!
Be aware that those brembo discs are known to warp. Couple of people I know and a couple on FT have had them warp too. You may not experience it but its been noted that its a problem with them. Brembo may have got on top of it with newer discs though, so you might be lucky!
PostPosted: Thu Mar 22, 2012 9:04 pm
All looking very good mate 8-)
PostPosted: Thu Mar 22, 2012 11:33 pm
TEAM AUBERGINE
PostPosted: Thu Mar 22, 2012 11:37 pm
TEAM AUBERGINE
PostPosted: Thu Mar 22, 2012 11:41 pm
Yeah you will feel the pedal go up and down slightly when braking if they are warped.
I dont know of what model of those discs are known to warp, wether it be the 'max' ones or a different type.. the 'max' ones may be better, who knows!
Hopefully you dont come across these problems, but its better knowing rather than not I guess! :)
PostPosted: Thu Mar 22, 2012 11:48 pm
TEAM AUBERGINE
PostPosted: Fri Mar 23, 2012 10:20 pm
right today i took off the other rear drum brake, then i had to get the two bolts off that held the rear axle on.
one came out. the other was seized in, undid by a few turns then the head rounded off and was well stiff!
not to worry.
i cut the axle off.
cut through the bolt (took some time its high tensel!!!) and got the axle off.
took the axle down the garden and burnt/ set fire to the bushes and pulled them out.
then went to scrapy to get new bolt (for axle same as the one i murdered.
got home found out the motorfactors had suplyed me with the wrong rear brake cyilinders so went out to shop and changed them.
also had to chase up rude racing as the goodridge brake lines they sold me had 2 wrong sized nuts. so goodridge themselfs are sending out some more to me.
oh and rottary wirebrushed and partly painted the brake drum plates and rear axle......
busy day.
TEAM AUBERGINE
PostPosted: Fri Mar 23, 2012 10:24 pm
Good work sam :)
PostPosted: Fri Mar 23, 2012 10:32 pm
TEAM AUBERGINE
PostPosted: Fri Mar 23, 2012 11:05 pm
fair play cant believe ive never seen this thread!
lovely car mate!
nice work recently as well!
attention to detail is where its at! i painted the bottom of my fiesta, best thing ive ever done lol
cars looking mint mate keep up the good work!
oh have you got a stainless mid section and de-cat? oz ive got both for sale foor £40 quid.
oh and some nice coilovers! lol
PostPosted: Fri Mar 23, 2012 11:29 pm
TEAM AUBERGINE
