Fiesta-Si.com • View topic - My Saph Cossie*Update- 30/03/2015 PG 137 - Running again*
It is currently Fri Mar 06, 2026 11:41 pm
Post new topic Reply to topic  [ 2732 posts ]  Go to page Previous  1 ... 120, 121, 122, 123, 124, 125, 126 ... 137  Next
PostPosted: Wed Feb 13, 2013 2:36 pm
Niiiiiiiiiiiiiiiiiiiiiiiiiice.
Also I still need your gear knob :)
And don't fucking quote that and change it you bellend! :D
PostPosted: Wed Feb 13, 2013 2:40 pm
PostPosted: Wed Feb 13, 2013 2:43 pm
PostPosted: Wed Feb 13, 2013 2:44 pm
ah the fabled green knob :lol:
PostPosted: Wed Feb 13, 2013 2:46 pm
PostPosted: Wed Feb 13, 2013 5:10 pm
Green penis.. mmm
PostPosted: Thu Feb 14, 2013 8:40 pm
Good work there Terry :thumbsup:
PostPosted: Fri Feb 15, 2013 9:35 am
cheers dave :thumbsup:
PostPosted: Tue Mar 12, 2013 4:33 pm
about time i updated this
not a great deal has been done to the saph recently but with my snowboarding holiday getting closer i thought id best put my xbox control down and get some work done!
first up was to complete the strip down of my head so i could have it dropped off for checking over while i was away on holiday
first up the inlet was removed
by , on Flickr
then came the exhaust manifold and cams
by , on Flickr
all removed
by , on Flickr
this is where things start to get a little interesting/disturbing :|
while removing the exhaust manifold i could hear some chining noises from the back of the head, i had a fish around in one of the head bolt holes and felt what i thought was washer!!
on closer inspection i saw it then proceeded to root the little fucker out with my fingers (couldnt find a magnetic jobbie thingy) anyways after some more rooting around 7 of the little turds appeared from inside my head..... :shock: (pic only shows 6)
by , on Flickr
by , on Flickr
now as you can see some look a little battered.... nothing really clicked until i started to remove the tappets and found this...
some tappets removed kinda looks ok here...
by , on Flickr
some more tappets removed..oh wait whats this.. :shock:
by , on Flickr
they were fucked! :shock:
by , on Flickr
my head was dropped off to have a check over
* Heli Coils on the cam caps and tensioner stud
* Valve stem seals
* tappet bores
the guy found another 2 washers in my head, so thats 9 in total!! :shock: :banghead: :doh:
i need to pop and see him this week to confirm stuff, but i think my heli coils were ok, valve stem seals need replacing and i need new spring washers.
he needs a new set of tappets to make sure the tappet bores in the head are ok :doh:
so hopefully i have been very lucky with this, only place and time i can think of that these washers came from was from when my bottom end went and i have ARP stud and nut kit!! but im sure most/all my studs have thier washers in the shed ( i need to check this)
i nevere heard anything moving about when the engine was put together the last time and just assumed the broken bits of tappet in my sump was from my old set when my cam snapped! F.M.L
Shopping list has already started for the rebuild, gonna be full steam ahead when it all arrives, i just need a hand from my ginger partner in crime to drop my sump and clear it out again and we're ready to roooock :thumbsup:
PostPosted: Tue Mar 12, 2013 4:38 pm
It's a good job you don't have a heavy right foot really! They are shot to pieces :(
PostPosted: Tue Mar 12, 2013 4:51 pm
my foot has been a little heavier since the live map!
they are savagely battered to say the least, cant believe i never picked up on them being in there for well over a year :cry:
PostPosted: Tue Mar 12, 2013 4:53 pm
At least you found it all out now before anything more serious could have happened :)
PostPosted: Tue Mar 12, 2013 4:57 pm
yeah your right, its a good job i "needed" to remove the head to have things checked over because i would never have known until something else failed, like my bottom end :lol:
PostPosted: Tue Mar 12, 2013 5:01 pm
fucks sake :doh:
hope it is all ok chap
PostPosted: Tue Mar 12, 2013 5:07 pm
PostPosted: Tue Mar 12, 2013 6:06 pm
Fuck a duck that was a close call!!!
Lucky you've got them out and all is ok though :thumbsup:
Paul
PostPosted: Tue Mar 12, 2013 8:25 pm
Christ, you were lucky there Terry! :o
Could have been alot worse :doh:
At least you have found the problem now while the car is off the road and in bits anyway :rolleyes:
PostPosted: Tue Mar 12, 2013 9:46 pm
hope its fucked then you can smash the 500bhp barrier you little cunt :thumbsup:
i joke youll never make 500 horses :P
PostPosted: Tue Mar 12, 2013 11:06 pm
what a fucking bellend
