Fiesta-Si.com • View topic - Diary of my Si, "JPH"
It is currently Sat Mar 07, 2026 2:22 pm
Post new topic Reply to topic  [ 516 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 26  Next
PostPosted: Wed Mar 17, 2010 11:33 pm
the new eagle steel rods in their new home
the head back together after being acid dipped clean, skimmed, new valve guides, recut seats + valves
the block was rebored again aswell
original 2.0 zetecs have a bore of 84.8mm making them 1998cc or 2.0
then this block was rebored for the first set of forged pistons at 86mm making it 2047cc or 2.1 as most know
ian decided to have it bored out further for me to make it 87mm - 2098cc
then he ordered new forged pistons and rods with my new measurements
heres my favorite pictures showing the cp pistons, freshly decked block and bores after being bored out and then honed
i love the reflections in the bores
PostPosted: Thu Mar 18, 2010 11:17 pm
Looking brilliant mate :thumbsup:
PostPosted: Fri Mar 19, 2010 7:48 pm
looks awesome mate.
PostPosted: Mon Mar 22, 2010 12:55 am
well i recieved the rest of my new skirts and arches kit,
also still brand new in ford packaging etc
so i have a full kit now woohoo
as i'm having new rose jointed lower arms and the rear beam bushes are powerflex,
i've been ordering more powerflex bushes
polybushes for the front and rear anti roll bar
my new steering wheel was becoming a bit of a knightmare as it use's a different steering wheel boss to the more well known
rs 3/4 spoke steering wheels
after lots of searching, i've sourced myself the right boss
so i'm mega pleased!!
fitted to the steering wheel
PostPosted: Sun Mar 28, 2010 9:20 pm
well its been a busy week just gone for me,
heres a few updates
taken the rear arch kit off which was bonded on previously
the sealer still left on the rear quarter
brand new wings arrived
as the shell is going to be seam welded mainly in the front,
the decision was made for it to be taken for a proper shotblasting session as the small kit i'd bought was'nt strong enough to get the sealer out properly to avoid
weld spitting when seam welding
so on the back of the truck the night before
the missus decided to take a picture
the next early morning ready to go for a trip to be blasted
PostPosted: Sun Mar 28, 2010 9:24 pm
so the car was back later the same day,
only problem being the weather was'nt on my side and was raining nicely
this made the journey back very interesting especially when the car cover kept blowing off the back letting the car get wet.
so some time with the airline and new cloth sorted that out!
the next night my fabricator decided to crack on now it was clean
so starting with the plasma cutter he cut out the problem areas of rust
heres some freshly cut holes
this is under the passenger side of the front bulkhead
this is the passenger rear turret
the nasty bits
the side showingno major signs of rust
also the start of the seam welding
PostPosted: Sun Mar 28, 2010 9:28 pm
inside the shell is'nt being left out either
the top of the bulkhead
the floor
decided to weld up where the plastic plugs normally go aswell
the main support on the floor, even welded a washer to support the seat bolt points which normally fracture
how the engine bay is looking from underneath
close up of the drivers front arch
heres a clear picture showing the supports used while welding the front end,
as we did'nt want that much heat going into the shell while being held up by the front and rear of the shell
you can see from the seams we intend to seam weld as their back to bare metal
also had the sealer cut off the rear quarters, so the rest can be removed by the fudge wheel
PostPosted: Sat Apr 10, 2010 8:34 am
ok time to catch up with a few updates
bought some 1.2mm thick steel which i had bent to my spec
then shaped it to meet the floor and sill inside the shell
which will reinforce greatly
here it is seam welded in postition
on the inside of the engine bay we used it to reinforce between the chassis leg and bulkhead
and sort the hole made by plasma cutting the grot out
will look like this
on the otherside of the bulkhead its look like this,
ignore the dodgy looking colour its from the gas used for welding
it comes off and will all be sorted before its first coat of etch primer
had my bigger master cylinder painted panther black aswell
so will build that back up soon
mmm metallic flake
PostPosted: Sat Apr 10, 2010 5:39 pm
Some seriously nice work going into that shell!!
Looked awesome in the first place, but that'll be minty mint when done!
Any tips on the seam welding? ;)
PostPosted: Sat Apr 10, 2010 7:26 pm
awesome :)
PostPosted: Sun Apr 11, 2010 11:08 am
PostPosted: Sun Apr 11, 2010 11:09 am
the seam welding has gone back to the rear floor
tidied the welds up a little and buzzed over them with the scotch wheel
the windscreen brackets were looking a rusty, so taken them off aswell
quickly machined the small scabs of rust around the sunroof to see the full extend of the tin worm
more welds cleaned up with the scotch wheel
PostPosted: Sun Apr 11, 2010 11:12 am
back on its side now for more welding underneath
the welds which have penetrated through when welding inside have been cleaned up
patches replaced where the metal has perforated after shot blasting
the inner fuel cap area was cleaned up but thin in a few places also
so that was cut out with the plasma cutter
the piece cut out
rear suspension turret where we cut out the rot has now had a new peice welded back on
this hole is where the bracket for the spare wheel carrier goes into the boot,
as i've taken all the other bracket off, i want this sealed up
so removed this extra support fords had over the top of it
PostPosted: Sun Apr 11, 2010 11:16 am
machined the sills back removing any chips in the previous paint etc
part of the front chassis welded up
the master cylinder back together
picked up some parts from the powdercoaters
rear beam, coilpack bracket and front mount
close up of the clean rear beam
now that its back, going to have the old man make up some spacers to make up for the width lost
when converting the rear brakes from drum to disc setup as the wheels sit further in the arch
PostPosted: Sun Apr 11, 2010 7:45 pm
getting there now
PostPosted: Sun Apr 11, 2010 9:41 pm
PostPosted: Mon Apr 12, 2010 2:44 pm
Any chance of the running total so far?
Looks awsome as ever.
PostPosted: Mon Apr 12, 2010 3:15 pm
stunning work! :bow:
PostPosted: Mon Apr 12, 2010 9:44 pm
PostPosted: Mon Apr 12, 2010 9:47 pm
