It is currently Sat Mar 07, 2026 7:00 pm
Post new topic Reply to topic  [ 2269 posts ]  Go to page Previous  1 ... 91, 92, 93, 94, 95, 96, 97 ... 114  Next
PostPosted: Fri Oct 19, 2012 11:22 pm
Twice in 2 day Ben.. :lol:
PostPosted: Sat Oct 20, 2012 9:38 am
i had already typed it before i asked you :P
love you guys
PostPosted: Sat Oct 20, 2012 7:57 pm
Glad your happy with the exhaust, let me know what it sounds like when it's up and running, is that how the parcel arrived to you? As it was fully boxed when I sent it...
PostPosted: Sun Oct 21, 2012 1:35 pm
Of course I will tony. Nice one.
No no. That was after I took a bit off ;)
PostPosted: Sun Oct 21, 2012 9:10 pm
right chaps.
engine is in the bay but not mounted up. will get pics up later but the space we had made it 1000x's difficult. there was me, my mate and his dad. both very knowledgable with cars.
alternator had to come off as did the manifold (which we scratched to fuck). i need to take the drive shafts out of the hubs to be able to get the engine mounted up.
they easy to get out? cant find my haynes atm so any advice would be awesome. hoping on getting it all mounted up tomorrow! thanks, Ben
PostPosted: Sun Oct 21, 2012 9:27 pm
Hi Ben
I never took the driveshafts out of the hubs, I just undid the pinch bolt at the bottom of the hub and pulled the whole assembly out of the way.
Duno if that helps?
Paul
PostPosted: Sun Oct 21, 2012 9:39 pm
oo good idea. but they're going have to come out anyway as i need the wheel bearings doing so it means the hubs are coming off. plus it means i can replace the gators whilst im at it! :)
PostPosted: Sun Oct 21, 2012 10:31 pm
In that case block of wood and hammer it through the hub from the wheel side if you get my drift?
Paul
PostPosted: Mon Oct 22, 2012 6:41 am
To get the shafts out the hubs you use a chisel or punch to bend the punched in metal out the way of the indented part of the hub nut, undo the hub but which will be so tight I really do suggest having the wheel on and the car on the ground. Once it's off, block of wood and tap it (or if like mine get a sledgehammer!)
PostPosted: Mon Oct 22, 2012 8:21 am
ill give it a go in a bit guys. problem is i cant get the car on the ground completely as the shafts will be in the way but ill figure it out :) thanks
PostPosted: Mon Oct 22, 2012 9:01 am
did you drop it in from the top or lift from the bottom?
as my alt and inlet were bolted on for all my conversions and the engine went in without an issue :?
also as said the shafts were left in the hubs but just pulled out the way until it was time to refit
good work though buddy, pics are needed :thumbsup:
PostPosted: Mon Oct 22, 2012 10:02 am
hi terry. bottom bud. i stupidly put the cv boots back in which just stopped the drivers side shaft from wiggling past. just popped it out and all is well! alt came off because (pictures will explain) we were lifting the engine under the car and didnt want to keep putting it on the alt. just got it back on as well as the belt :)
exhaust mani had to come off because of the shaft was against the oil filter lol! so we were having to tip the engine forward whilst lowering the car, mamikng sure the oil filet or shaft was damaged, so the mani had to come off to do that :( so ill hopefully be able to bolt that on when i get back from work at 3!
and yes, pics will be posted bud :) ill put a couple in now.
as for the hub nuts, what size are they as i dont have a socket big enough! is it 32mm?
PostPosted: Mon Oct 22, 2012 10:04 am
taster
built up
in'ish
PostPosted: Mon Oct 22, 2012 10:37 am
good work there buddy!
look at those pics im pretty sure the engine number is on the flat part of the block closest to the gearbox where the cps is mounted! but youve painted over it, ooops! hopefully you'll be able to make it out without having to remove the paint :doh:
i can circle it if you want?
PostPosted: Mon Oct 22, 2012 1:14 pm
nearly there scouse ;)
PostPosted: Mon Oct 22, 2012 4:54 pm
I was just away to post the same as Terry, think you'll have to scrub that paint off to get the no if i'm honest :(
Might get lucky though!
Looks good though bud, keep it up :)
Paul
PostPosted: Mon Oct 22, 2012 6:52 pm
yeah if you could circle it please Terry :)
its in! properly. pictures soon chaps. over.the.moon
PostPosted: Mon Oct 22, 2012 7:58 pm
have a look at where the red arrow is pointing, the number should iirc be there
PostPosted: Mon Oct 22, 2012 8:38 pm
:teehheee:
I never told the DVLA, told insurance but not them, didnt see any point, after all it didn't change tax bracket etc. But hay thats me, not afraid of the law :wack:
PostPosted: Tue Oct 23, 2012 8:17 am
badass muthafuka! :lol:
