It is currently Mon Mar 09, 2026 10:01 pm
Post new topic Reply to topic  [ 2269 posts ]  Go to page Previous  1 ... 89, 90, 91, 92, 93, 94, 95 ... 114  Next
PostPosted: Thu Sep 27, 2012 9:46 am
yeah but you had 45 profile :P but i completely agree, a lot of st's seem to have them, so my alternative is toyos i guess. thanks for your input though hun :)
PostPosted: Thu Sep 27, 2012 10:18 am
but i had 17" wheels - 15's are better for handling ;)
toyo's will be good though :)
anytime ;)
PostPosted: Thu Sep 27, 2012 12:18 pm
cool man, glad we came to an agreement ;)
PostPosted: Thu Sep 27, 2012 9:27 pm
staying silver mate. went from green to copper then decided on silver. clean cut. dont want this car to look chavy at all (not saying people with different coloured calipers are!) but round here thats what people think lol. want it to look as standard as possible tbh :)
forgot to order slider pins so theyre on the way.
ive painted up the engine mounts today and mock fitted them
the pas pipe was fouling the space where the bracket fixed to so i had to re bend that once again. a quick question, the bolt heads dont seem to be big enough, will some washers sort that or does the head need to be bigger?
and the ho inlet in position finally
EDIT-noted that washers came as standard for the mounts so they will be sourced tomorrow hopefully :D
PostPosted: Fri Sep 28, 2012 12:30 am
As much as I take the piss. I've got to be honest, your doing well :)
Good on you for painting everything, rocker cover, wheel colour imo, but your doing exactly what I want to do but sooner, keep at it and make it look sexual, green calipers might have made it look lairy and not "smart" try and keep it OEM+ and smart looking instead of sort of "track, euro" or something similar, could come out pretty good ;)
PostPosted: Fri Sep 28, 2012 1:00 pm
lol thanks Chris, knew you would be nice eventually :P
rocker cover is going crackle black! it came red, bloody hate it lol. but thanks, that is exactly what i want, oem big time. glad you understand. hope to see you doing this soon then :) wish i could go a bit more crazy ie more power, full shell jobby etc but for my age and income, this is perfect :)
little update, flywheel was only dropped off today sadly, but gives me time to make sure i have everything ready :) quick question also, will i be able to fit the ashley manifold once the engine is in? thanks
PostPosted: Fri Sep 28, 2012 1:25 pm
Looks good mate :)
Yeah put the manifold on once the engine is in... It will probably be a tight squeeze between the manifold and the rad fan though, but you'll get there with it :)
PostPosted: Fri Sep 28, 2012 2:00 pm
well could i put the rad fan in afterwards?
thanks danny. just need tonwah to contact me back otherwise im going to have to source another system.
PostPosted: Fri Sep 28, 2012 2:06 pm
Yeah that'll be the easiest way
PostPosted: Fri Sep 28, 2012 2:19 pm
cool beans danny :)
PostPosted: Fri Sep 28, 2012 4:39 pm
right, as title states, i took the newly refurbished calipers out of the box to show my dad and boom, bits of rust are starting to sneak through the silver paint. now i know i went for the standard finish. but i did not expect this and am very disappointed. ive emailed biggred so im not sure what their reply will be. what do people reckon on this? am i being a bit moany or should i be pissed of?
PostPosted: Fri Sep 28, 2012 5:08 pm
right had a reply, wish id listened to them in the first place! my own fault for choosing a standard finish (finished with a can of spray yet still sand blasted). getting them zinc plated now instead, wish id chosen that in the first place, stupid fucking me.
PostPosted: Fri Sep 28, 2012 5:15 pm
Right. issue. i did bring this up in the technical forum but i dont see how i can do it. the nut will not fit through any of the holes, do i need to cut a small section out to be able to get the nut in? i know that might weaken the chassis leg slightly but thats all i can think of?
does it need bolting from this side also?
thanks, Ben
PostPosted: Fri Sep 28, 2012 6:17 pm
Where are you trying to get a nut into?
And yeah it needs bolting from the back too.
PostPosted: Fri Sep 28, 2012 6:30 pm
from top. i need hex rivnut fixings :( just ordered some
PostPosted: Thu Oct 11, 2012 8:57 pm
evening shanters...
a little update tonight. will begin with the rocker cover...
hammered black (not majorly hammered as its only hammered hammertie but it gives a nice slight hammered effect ;)
will be getting either black or grey ht leads too but the red ones will do for now.
managed to get hold of an rs1800 fuel rail wiring box (big thanks to AWOL)
will my 1.4si wiring be ok? eg do all the connections i need look like they're there? i will get to that when i whack it in tomorrow so its just to check.
my torque wrench arrived. draper jobby. has been calibrated etc with paper work to prove its all in good working order.
and finally, my ferodo pads and disks arrived!
free air freshener (for my wait?)
and one with them behind the wheels just to get the feeel for it :teehheee:
now onto the more important shit!
i sent my calipers back to get them with a polymer coating as its the best and most durable finish they offer. sadly they dont do silver so i chose black. now yes, you can say that's a boring choice on my behalf but i thought logically. wont show dirt as easily and it will look oem'ish!
my theme will be black and grey/anthracite etc etc. boring but clean cut imo.
which leads me onto my next purchase (which will be at the end of this month)... samco gun metal grey hoses.
thought i may as well, spend enough so far so i dont want to cut corners. so they will be ordered in due course.
will be fitting my front mount tomorrow. i cba forking out 50 odd squid on a rivnut tool, so ive got a method that may or may not work. if not it will be a straight through nut and bolt jobby.
still waitng on the flywheel so watch this space.
peace & love
Ben
PostPosted: Thu Oct 11, 2012 9:04 pm
Needs bigger brakes.
PostPosted: Thu Oct 11, 2012 9:09 pm
thats what i thought haha
PostPosted: Thu Oct 11, 2012 9:26 pm
Get some 280's or shave some 300's under there!
PostPosted: Fri Oct 12, 2012 12:31 am
Nice little update Ben. RS2000 brakes aren't all that bad, bigger would look better though :)
Fuel rail wiring looks ok to me, looks like all the correct plugs are there.
Sort the HT lead wiring out though, it's pissing me off being a mess like that :)
