Fiesta-Si.com • View topic - Project KA170 - Just incase you didnt believe me...
It is currently Fri Mar 06, 2026 11:11 pm
Post new topic Reply to topic  [ 354 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 18  Next
PostPosted: Thu Apr 28, 2011 8:50 pm
if you chose this shell then the fiesta shell must of been shagged really bad
PostPosted: Fri Apr 29, 2011 12:35 am
Apart from the usual sills, the usual floorpan bits which go on all fords around the seat mounts, and the filler cap this shell is pretty good.. specially for its age.
FFS I have seen a newer ka with worse filler panels :lol:
All of the above I have found has been hiding under seam sealant!!!
Luckily there isnt anything too major... the bootfloor and rear panel bit is pretty simple to sort and means I have fit a battery recess into it :) - the rear of the arch shite isnt tooooooo bad, just awkward.. but as the arches cover it im not arsed what it looks like as long as it seals up the cabin and does the job ;)
PS. Yes the fiesta shell was mega fucked. Inner sills were missing, half the floor pan was fooked, needed all the panels replacing.. the ka will only be seeing the filler panel, sills and a bonnet :)
PostPosted: Fri Apr 29, 2011 11:06 am
I think my car needs to come down to your shonkworxs and get some welding lol
PostPosted: Fri Apr 29, 2011 7:20 pm
not as bad as i was expecting to be honest. the idea for sorting out the back is about right. its just going to be a test of patience for you ;) if in doubt make bits in card first and trial fit then cut the steel..im sure youll be fine..fancy attacking that other fiesta in there with a grinder? :P
any and i mean any shell you buy unless you get it in a stripped state, will be hiding something generaly, and this in comparison to the previous hunk of shit RS1800 is a minter. as paul said there was so much rot it was silly it was starting to bend on the spit. it had to go.
:lol: youll have to find the cave and paul has to fix the welder first :D
PostPosted: Sat Apr 30, 2011 12:29 am
Good progress there Paul :thumbsup:
I see you have taken a leaf out of my books with the block usage :lol:
PostPosted: Sat Apr 30, 2011 10:53 am
That fiesta in shonkworx can stay under its cover, I'm not going to be touching that until you start hah
Will you be needing the spit?? As the KA won't go on it due to the KA having no mounting points for the bumpers (they clip/screw on)
Soon as I sort this welder... I'll make a start on the KA welding fun... but I have a feeling the welder is fucked
PostPosted: Wed May 11, 2011 5:45 pm
PostPosted: Wed May 11, 2011 6:42 pm
Pretty cool but why they using a vag engine? :(
PostPosted: Wed May 18, 2011 1:59 pm
because he's an egg in the nest. sick though
PostPosted: Wed May 18, 2011 3:55 pm
Pfft, ST170 on R1 ITBs is where its at
PostPosted: Wed May 18, 2011 3:57 pm
what is a vag engine paul?
and quick question whilst its on my mind... if you change brake pads, do the brakes need bleeding?
PostPosted: Wed May 18, 2011 6:54 pm
Volkswagon Audi Group....
Erm, don't think you have to, but I would
PostPosted: Wed May 18, 2011 8:16 pm
PostPosted: Wed May 18, 2011 10:42 pm
You not sorted the rust out yet Paul? C'mon! Chop chop ;) :lol:
PostPosted: Wed May 18, 2011 10:48 pm
cheers paul
PostPosted: Thu May 19, 2011 7:59 am
I got my "new" welder last night, which I won off ebay... which was at my uncles place of work :lol:
Got some reels of wire for free too :D
Just need some gas and then I'll be making a start to welding the Ka up to be rust free ;)
PostPosted: Wed May 25, 2011 4:30 pm
Got a welder, it works, as I welded up my mums berlingo exhaust last night to save £80 :lol:
Got some good mods coming for the KA soon which will see it deck on coilovers / white wheels / arches for a nice porn photo within the next week or so ;) - Just gotta make a mount so I can fit 3.5 coilovers to a KA :lol: - KAOC will love that one I'm sure :lol:
Progress will be moving on this beast now I have a mig so don't you worry ;)
PostPosted: Wed May 25, 2011 4:32 pm
good work :chill:
PostPosted: Wed May 25, 2011 8:31 pm
Sounds good Paul :chill:
PostPosted: Thu May 26, 2011 7:01 am
get cracking slim :D
Users browsing this forum: Google [Bot] and 62 guests
