Fiesta-Si.com • View topic - To the death hopes and dreams
It is currently Fri Mar 06, 2026 3:17 pm
Post new topic Reply to topic  [ 316 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 16  Next
PostPosted: Tue May 15, 2012 7:39 am
You're a cheeky fooker!!
Yeah I will lol.
PostPosted: Tue May 15, 2012 9:43 am
Cheers mate lol :thumbsup:
PostPosted: Thu May 17, 2012 7:01 pm
To level off the top of the tyre against the peak of the arch, it's 60mm on the back and 50mm on the front.
I might go 35 on the front and 50 on the back :)
PostPosted: Thu May 17, 2012 7:03 pm
Tyre or rim? Depending what one makes a big difference lol
PostPosted: Thu May 17, 2012 7:53 pm
Top of the tyre, the visible gap back to the spring/damper.
PostPosted: Thu May 17, 2012 7:55 pm
And yeah yeah, take the piss!!
PostPosted: Thu May 17, 2012 8:03 pm
Okie dokie, ill have to add rough tyre wall hight to that then lol
PostPosted: Thu May 17, 2012 9:29 pm
Yours is 195/45/16 right?
I've got 195/50/15.
PostPosted: Thu May 17, 2012 9:39 pm
Nah I have 195/45/15.
Tyrewall height is something like 97mm. so ill just add that to the above :)
PostPosted: Thu May 17, 2012 10:22 pm
Going through insurance. Getting depressed. How can insurers justify a 40% increase...?
PostPosted: Thu May 17, 2012 11:13 pm
I've just had the same thing, very annoying.. A year older, a years extra no claims and a £350 increase.. Thanks for that..
Assholes!!
PostPosted: Thu May 17, 2012 11:35 pm
Did my tracking again earlier today after getting a couple more modification items from the scrappy.
Picked up two door rubber strips from a mondeo along with the sun visor lights from the same car. The strips are those ones that go right in the external door gap. With some good fitting these are perfect, just the right size against the standard door rubbers and have a little edge that should poke into the gap nicely. The little lights should be a nice addition in the sun visor recesses.
Tracking now has no pulling at all but needs tweaking to centre the steering wheel correctly as it's ever so slightly to the left. It used to pull to the left a little and the wheel was off centre to the right. Think I need about half a turn on each wheel to remove the left issue.
PostPosted: Fri May 18, 2012 2:25 pm
Thanks for the measurements :)
Measured mine today, lowered roughly 100mm on the rear and roughly 90mm on the front :D
The joys of coilovers lol
PostPosted: Tue May 22, 2012 8:18 pm
Well, got a bit of an update.
Up he goes:
Then had to have a look at this wheel:
Been getting a noise from the front end linked to road speed. Looks like the drivers side caliper is sticking a bit, then grinding and vibrating when pressure is released off the pedal and yes, it threw off the caliper retaining spring. Adjusted the calipers and what I did was move one spacer on the bolts (they're just too long for the fiesta hub holes) from under the head to between the hub and the mounting bracket. Centres the caliper better to the disc.
Then I went and organised everything for the shed as I have had too many bags and boxes of mixed bits and I can never find anything!
Got this sorted, general bits in the top:
Turning tools - but not adjustable or swappables:
Then socket bits:
Then I found this bag - whoops. Completely forgot this stuff was in the car!
I never realised how much stuff I have, because there's more...
Autoglym stuff:
Random car bits:
I think that's enough pics for now!
PostPosted: Tue May 22, 2012 9:21 pm
Can never have too much stuff :D lol
PostPosted: Tue May 22, 2012 9:34 pm
Rofl, forgot the most important change I did today.
PostPosted: Tue May 29, 2012 2:28 pm
yes dan! got the servo, thanks bud ;) whats up next with it then?
PostPosted: Tue May 29, 2012 2:47 pm
Needs mk5 wiper and rust sorting next!
PostPosted: Tue May 29, 2012 2:58 pm
jib the mk5 wiper, just rust it
PostPosted: Tue May 29, 2012 3:18 pm
Yeah no stuff like that for me. If it looks standard or improved (like the sunroof) it'll go on. Lots of little bits of rust to solve too.
Glad you got it Ben, did you like the surprises?
