Fiesta-Si.com • View topic - *Mk3 1.1 Runabout - Update 04/01/12 - SUSPENSION*
It is currently Fri Mar 06, 2026 9:16 am
Post new topic Reply to topic  [ 249 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 13  Next
PostPosted: Thu Jan 05, 2012 12:33 pm
just a quick question about the stabilizer bar. does it make much difference between the 16mm and 12mm? (mine is a td engine so its quite heavy)
PostPosted: Thu Jan 05, 2012 12:41 pm
PostPosted: Thu Jan 05, 2012 12:43 pm
yes
PostPosted: Thu Jan 05, 2012 12:59 pm
Get some pictures up, wanna see it.. I miss my TD.
Anyway, fit Si roll bars to it :)
PostPosted: Thu Jan 05, 2012 1:59 pm
what mm are the si roll bars ?
my current suspensions doent have where i can connect the anti roll bars I still need to figure a way to connect them without replacing the suspension.
also planning to add the S bracket and rear anti roll bar (also still need to figure a way how to connect them without replacing)
still have to polish the top cover but will do that later when the car is ready, also got a much bigger intercooler and am currently waiting for the silicone pipes to arrive before I fit it.
http://www.freeimagehosting.net/4a1ad
http://www.freeimagehosting.net/9509d
PostPosted: Thu Jan 05, 2012 2:48 pm
Pretty sure they only made one size.
You could weld brackets on your shocks for them, easy to replace the shocks.
Rear arbs you need a beam for it, could maybe mod a standard one tho.
You upped the fueling and boost? Don't go above 22psi lol
Turn inner pump screw 90 degrees.
I got 105bhp and 180ftlbs out of mine.
PostPosted: Thu Jan 05, 2012 2:50 pm
it has a bosh fuel pump and with bigger turbo ... used to run on 30psi :p I think that it is about 120-130bhp
ye probably I will weld but first I need to have the parts before I can begin hehe.
is there any special purpose why the S bracket has like a form of an S ? or can I just use a normal heavy duty pipe ?
PostPosted: Thu Jan 05, 2012 3:54 pm
Think it was just made like that due to the mounting position.
In theory you could just make one up yourself.
If your car doesnt have the captive nuts you'll have to fit some into the holes to bolt something up.
With regards to the 30psi & 120-130bhp.. I want to see it RR'd to prove it, everybody asumes they can produce that power, but I have yet to see anything RR'd above mine (admitedly mine was the lucas pump)
PostPosted: Thu Jan 05, 2012 4:03 pm
hopefully when its done Ill do a project thread and a dyno test. Do you have a project thread on urs?
PostPosted: Thu Jan 05, 2012 4:06 pm
PostPosted: Thu Jan 05, 2012 4:19 pm
ic ic. maybe when ill have time ill start doing a project thread :) it is quite long hehe
PostPosted: Thu Jan 05, 2012 8:00 pm
PostPosted: Fri Jan 06, 2012 12:18 am
pov spec fiestas had a 12mm front arb, no rear obviously
16v si and other sporty models had the 16mm front bar and 16/18mm rear (18 im sure)
anything planned next dave?
PostPosted: Fri Jan 06, 2012 12:27 am
Poverty spce didnt have any anti roll bars on them mate :thumbsup:
And the rear ARB is 20mm in diameter :)
In terms of plans, just drive it as the daily for the worst of the weather ready for the si to come back on the road in the spring :D
Need to put a new front panel on her when she comes off the road in the spring
Other than that, just enjoy the HCS tappet rattler engine :halo: :lol:
PostPosted: Fri Jan 06, 2012 12:50 am
PostPosted: Fri Jan 06, 2012 1:12 am
hmm trying to think what did have the smaller arb, maybe the mk4s?
ugh confused now
PostPosted: Fri Jan 06, 2012 2:51 pm
I know my sisters old mid spec 1.3 mk4 had a front arb but not a back one, but not sure on the diameter
Don't really care about the mk4 either :lol:
PostPosted: Fri Jan 06, 2012 3:23 pm
Is there any sort of chance you could nock up a guide to replacinf the basic panels like sills, front wings and front and rear valances?
Basically where to cut and weld them? And would you paint them once fitted or before?
PostPosted: Fri Jan 06, 2012 4:14 pm
id appreciate that myself
haha boo ALL mk4s!
PostPosted: Sat Jan 07, 2012 9:39 am
I kind of pretend the mk4 doesnt exist :lolz:
Fair enough, there are a couple of nice ones on the scene, but they are severe exceptions :lol:
I will sort out writing a guide when I have some spare time on my hands, and in the meantime, just phone me up or send me a pm for specific advice if you need it :)
