Fiesta-Si.com • View topic - The Orange Si *attempted theft*
It is currently Fri Mar 06, 2026 4:23 am
Post new topic Reply to topic  [ 149 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Thu Mar 24, 2011 1:09 pm
PostPosted: Thu Mar 24, 2011 2:28 pm
Will I need a 1.6si one or one from a 2.0 mondeo?
PostPosted: Thu Mar 24, 2011 2:55 pm
i would hazzard a guess at a 2.0 one as your using a 2.0 ECU :thumbsup: ... try a scrappy for lambda they usually have loads of mondeos :D
PostPosted: Thu Mar 24, 2011 7:05 pm
i fitted 2ltr one bout 2 month before you picked car up with you havin 2ltr ecu now its gotta be matching lambda sensor
PostPosted: Fri Mar 25, 2011 8:01 am
yeah it's failed by the looks of it now.
it's now had majority of parts replaced so as it's started munching fuel I'm going to get a different lambda on it and see how it goes.
I reckon it's over/under reading the exhaust fumes as the ECU seemed to screw over the other 2.0 maf when it ws changed (causing it to stall a lot) put the newer maf on it no more stalling 4-5 days later it starts eating petrol.
trial and error so far.
last Friday it had spark plugs/leads/belts/fluids done so it getting narrower as to whats left :lol:
PostPosted: Fri Mar 25, 2011 8:30 am
jus had a thought the ICV does that one need to be changed for. a mondy one or is the 1.6 one ok to leave on?
I know that the ICV is a decent 1.6 (off my red si which had no idle issues) and the one I removed was also a 1.6 ICV (same part number)
I don't think I've seen anywhere that that needs changing though, could be wrong ;)
PostPosted: Fri Mar 25, 2011 11:54 am
ISCV should be fine, my si is running a good 1.6 ISCV and Lambda sensor and it was running fine when Jamie took it, have never changed it on any of my conversions never been a problem :)
PostPosted: Fri Mar 25, 2011 12:11 pm
well I've found a lambda sensor that does the early mk1(and some other fords) and also does the mk3 fiesta (incl 1.6si)
so will probably give that a try.
car would be ok just the fuel munching is doing my head in.
PostPosted: Fri Mar 25, 2011 11:18 pm
news travels fast where I live.
people only just found out I'm getting a new car and I've had someone round here to put an offer on my fiesta :lol:
it's tempting but I love the damn thing so much.
PostPosted: Sat Mar 26, 2011 11:03 am
think long an hard an if you get a good price for festa go for it can allways get another 2ltr later on lol
PostPosted: Sun Mar 27, 2011 9:55 am
32coupe did you ever replace the speed sensor?
I might replace the lambda and the speed sensor :)
PostPosted: Sun Mar 27, 2011 4:46 pm
no i didnt just maf and lamda sensor
PostPosted: Sun Mar 27, 2011 6:16 pm
197 clios are prity dam good cars
PostPosted: Sun Mar 27, 2011 8:50 pm
cool I think that's another issue with it ;)
it's getting there sounds so much/runs so much better. just need it to be perfect.
jimbo yeah they are quite nice. can't wait to get it remapoed + exhaust + filter done hopefully push it just over 200bhp then later on cams + another remap 225+ HP with any luck.
although ideally would prefer to up the torque dramatically.
PostPosted: Tue May 17, 2011 11:40 pm
update on this. Not a good one either :(
some little twunt has tried to get into the car and jacked the door edge in by the lock.
Will show pictures later of the damage. I'm hoping I can get it back with a rubber mallet.
I'll take a hit on the price for it though which isn't a bother to me as long as it stays on the road.
PostPosted: Wed May 18, 2011 9:46 am
Little bastards, atleast they didnt steal it, luckily mk3.5's are harder to get un than mk3s as they have a plate behind the lock.
My partner locked her keys in her corsa and her uncle showed me how easy that was to break into.
PostPosted: Wed May 18, 2011 11:43 am
Thats bad news! Get some pics up of the damage!
PostPosted: Wed May 18, 2011 1:20 pm
lmao you can show me that at sixfields lou!
and thats shit news. i kind of know how it feels to get little bastards abusing my car. i reckon yuo could knock it back with a mallet easy, just make sure you have something solid behind it so you dont dent it in. or get a pro job but yeah, aeseholes, they will get whats coming to them.
PostPosted: Thu May 19, 2011 1:08 am
P*ssed off wasn't the word when I saw this!
PostPosted: Thu May 19, 2011 8:46 am
Even if you do get that straight, its going to leave a big crease in the door :(
