It is currently Fri Mar 06, 2026 1:22 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1145 posts ]  Go to page Previous  1 ... 52, 53, 54, 55, 56, 57, 58  Next
PostPosted: Thu Jun 21, 2012 8:02 am
TBH I think I over did mine (as thats what I do) and its squashed the gasket making it leak at the weak point at the gearbox end in the half moon part.
Gonna drop exhaust / starter off, drop sump off, clean it all back up...
Stick the gasket to the block using bolts to locate it and hold it in place, once set, gasket sealer the sump side, and fit the sump, and not fit the bolts as tight.
As long as it is the sump gasket, that should stop my leak.
If it doesn't, I won't be going on track at Ford Fair, as it pisses out when warm.
PostPosted: Thu Jun 21, 2012 8:32 am
fingers crossed paul!
PostPosted: Thu Jun 21, 2012 9:31 am
As you said, sealant should help. Some RTV stuff will do the job. That's what a lot of newer ford use as opposed to a gasket where it's just two flat surfaces on them now with no ridge for a gasket.
PostPosted: Thu Jun 21, 2012 9:37 am
I've got some blue stuff that should do it
PostPosted: Thu Jun 21, 2012 9:52 am
Yeah that should be alright. I've seen that used on most parts of an engine just as a fail safe.
Hope it gets sorted :)
PostPosted: Thu Jun 21, 2012 10:33 am
well I'm gonna stick gasket to block first.
lather the sump in sealant.
it better work.
PostPosted: Tue Jul 10, 2012 12:18 pm
PostPosted: Tue Jul 10, 2012 12:21 pm
More RS2000's? :lol:
If you sell get that cage out and sell it to me :)
PostPosted: Tue Jul 10, 2012 12:24 pm
rs200's chris :P
paul you love it really :)
PostPosted: Tue Jul 10, 2012 12:26 pm
Nice list... you'll be busy!
PostPosted: Tue Jul 10, 2012 12:36 pm
Welding is a days work. So not too bad.
Brake lines & battery is an afternoon.
Wheels, not much.
You get the picture :lol:
PostPosted: Tue Jul 10, 2012 12:56 pm
Good list of plans there Paul :thumbsup:
PostPosted: Tue Jul 10, 2012 1:52 pm
Oh and Chris, good luck to anyone to remove that "bolt in" cage haha
PostPosted: Tue Jul 10, 2012 1:54 pm
BZZZZZZZZZZ lol You can get weleded ones out :)
PostPosted: Tue Jul 10, 2012 2:03 pm
It would be fucked lol
PostPosted: Thu Jul 12, 2012 6:52 pm
Had the afternoon off so I managed to seam seal all the welding on the front end of the floorpan, and I painted the passenger side floor.
Need to weld another patch on the underside of the drivers side, but other than that the floorpan is done.
I will get there eventually :lol:
PostPosted: Thu Jul 12, 2012 7:02 pm
Good progress paul, nice one :thumbsup:
PostPosted: Thu Jul 12, 2012 7:24 pm
Its still a rusty shed of shit, but it should last me a little longer :lol:
PostPosted: Thu Jul 12, 2012 7:27 pm
Progress is progress :)
PostPosted: Fri Jul 13, 2012 8:25 am
nice one
