Fiesta-Si.com • View topic - my List of Faults
 Post subject: my List of Faults
PostPosted: Tue Jun 21, 2005 6:26 pm
well i have found this morning that my rev counter does not work anymore
any1 have any idea what could be wrong i have check the haynes manual and it does not anything in there!
my reverse light does not work, the bulb is fine i was told its the sensor!
and my oil warning light does not work i am hoping its the bulb!
shacky steerin when i brake, read somewhere it could bw warped brake disks
can any1 shed any light on how to tackle these probs
need 4 new tyres too
oh and abit of rust in the boot area!
PostPosted: Tue Jun 21, 2005 11:32 pm
Rev counter: check the simple things first, take off the clocks and make sure the line hasnt come loose or twisted.
Juddering when braking: sounds like the dics mate. I had the same, changed the discs and pads and all is good :)
Reverse light: if the bulb is ok, check your wiring. Otherwise, dont ask me about the sensor as I havent got a clue :lol:
 Post subject: Re: my List of Faults
PostPosted: Wed Jun 22, 2005 10:30 am
Rev counter just stopped working? Could be a wire not working been as you're saying that the oil light isntworking either, a few wires on the multiplug could have worked loose. If you've got a mate with a Fiesta, ask nicely if you can rob his clocks and try them. Then you'll know if its a fault with the clocks/lights or the wiring.
Shaking through the steering will most likely be warped disks. Replace the pads with the disks and dont be a tight ass :lol: or else they'll just warp again. BED THEM IN :P No hairing around for a few hundred miles or you'll glaze the pads.
Rust? Bah, I don't do rust. :)
PostPosted: Wed Jun 22, 2005 5:01 pm
PostPosted: Wed Jun 22, 2005 11:36 pm
PostPosted: Thu Jun 23, 2005 8:03 am
will do!
cheers for all the help
PostPosted: Sat Jun 25, 2005 6:41 pm
PostPosted: Sat Jun 25, 2005 7:51 pm
no, thats why the gay red hazard light on top of column flashes..
ford so cheap, didnt even put directional indicator lights in :(
