Fiesta-Si.com • View topic - Nocking from rear of car
It is currently Thu Mar 26, 2026 2:58 pm
 Post subject: Nocking from rear of car
PostPosted: Sun Oct 14, 2007 3:48 pm
PostPosted: Sun Oct 14, 2007 5:04 pm
check all the bolts on the shock are tight, could be a lost bolt somewhere 8-)
PostPosted: Sun Oct 14, 2007 5:27 pm
Exhaust??? :)
PostPosted: Sun Oct 14, 2007 6:57 pm
PostPosted: Sun Oct 14, 2007 7:30 pm
wheel bearing or stuck on rear brake shoe maybe
PostPosted: Sun Oct 14, 2007 7:42 pm
my car bangs from the back... i got a new exhaust rubber and that stopped it... untill it went lose again :)
PostPosted: Sun Oct 14, 2007 10:39 pm
PostPosted: Sun Oct 14, 2007 10:40 pm
PostPosted: Sun Oct 14, 2007 10:41 pm
PostPosted: Sun Oct 14, 2007 10:53 pm
Dont have lower arms on rear.
I had a knocking at the rear when i had my fiesta lowered too, i turned out to be the nut on the top (inside the car) not tightened, try that! ;)
PostPosted: Sun Oct 14, 2007 10:54 pm
ok cheers for that m8 how much u lower yours by then i got mine 40mm all round n its proper bumpy on the bak over bumps n the front right scrubs like any thing over bumps im goin to get sum 195/45 tyers see if that makes a difference
PostPosted: Sun Oct 14, 2007 10:58 pm
what size tyres you got on now? 195/45/15 should be sound with 40mm drop!!
sounds stupid but different fiestas vary with scrubbage, two si's could have identical wheels, lowering, 1 would drive sound and the other scrub like a bitch.
:rolleyes:
Mine was 60mm and had 195/50/15's on it, had to do some cutting to the front arches to stop the scrapping, but the rear was fine bar the odd bump in the road at speed! :)
PostPosted: Sun Oct 14, 2007 11:00 pm
ive got 195/50/15 yeh i dnt wan cut the front tho incase i fluff it up lol its onli the front right there is like a clip it feels lie on the right but its not on the left one so i wunder if i cut it of the right it mite not scrub
 Post subject: exhaust
PostPosted: Mon Oct 15, 2007 8:29 am
the exhasut sounds like its hitting the body a exhasut mount sounda like it has gone
PostPosted: Mon Oct 15, 2007 8:33 am
PostPosted: Mon Oct 15, 2007 8:46 am
PostPosted: Wed Oct 17, 2007 5:33 pm
