Fiesta-Si.com • View topic - i will pay £5 for help.
PostPosted: Mon Oct 08, 2007 11:05 pm
is there any chance someone can have a look under their bonnet of there 1.6 for me please?
im trying to fit the fiesta si loom into my mk4 escort with a zetec engine.
the thing is i cant figure out where all the wires go and i have looked in haynes manual and the online manual too with no success.
the problem is i cant find the wire that goes onto the white block on the back of the coil pack!
also i cant find out what wire should go to the temp sensor on the front/ bottom of the thermostat housing.
i have a plug with 4 pins but only 2 wires on it, its the same shape as the lambda sensor plug but with just 1 brown and 1 brown/green stripe wires.
also what colour are the injector wires on each injector from 1-4?
PostPosted: Tue Oct 09, 2007 7:28 am
If nobody else does before me, I'll have a look at mine as mine just so happens to be in my garage at the mo ;)
Will try and get some pics for you if I remember later :lol:
PostPosted: Tue Oct 09, 2007 5:35 pm
PostPosted: Wed Oct 10, 2007 7:27 am
PostPosted: Wed Oct 10, 2007 5:55 pm
PostPosted: Wed Oct 10, 2007 6:45 pm
avoid mtech like the plague!
PostPosted: Wed Oct 10, 2007 10:48 pm
PostPosted: Thu Oct 11, 2007 6:47 pm
PostPosted: Thu Oct 11, 2007 10:27 pm
haha bet you wish you were an auto electrician now ay.
You will definitely need to get your hands on a copy of TIS other wise its going to take you ages to get some one to help you. I'd help you but its a long process mate shame your not nearer.
PostPosted: Thu Oct 11, 2007 10:40 pm
PostPosted: Fri Oct 12, 2007 8:19 pm
the top plug that looks like a lamda sensor plug has got to be engine temp and the two pin oval one im guessing is fan switch.
the other is engine temp for dash.
so im just stuck on the loom into the car
PostPosted: Mon Dec 03, 2007 7:52 pm
PostPosted: Mon Dec 03, 2007 11:26 pm
PostPosted: Mon Dec 03, 2007 11:33 pm
harsh, im trying to get mine sorted, trying to figure out the ecu,
using a 1.6 16v si engine loom, at the mo ive got aescort gti ecu that came with the engine, i was told that is was external pats and internal edis so i thort it could work, but having trouble with the pin swaps, what ecu did u use mate?
as after one thats not silly money, and one i can get hold of also
PostPosted: Tue Dec 04, 2007 9:55 am
Users browsing this forum: No registered users and 85 guests
