Fiesta-Si.com • View topic - i need help with fiesta si loom
PostPosted: Sun Oct 07, 2007 12:08 pm
is there any chance someone can have a look under their bonnet of there 1.6 for me please?
im trying to fit the fiesta si loom into my mk4 escort with a zetec engine.
the thing is i cant figure out where all the wires go and i have looked in haynes manual and the online manual too with no success.
the problem is i cant find the wire that goes onto the white block on the back of the coil pack!
also i cant find out what wire should go to the temp sensor on the front/ bottom of the thermostat housing.
i have a plug with 4 pins but only 2 wires on it, its the same shape as the lambda sensor plug but with just 1 brown and 1 brown/green stripe wires.
PostPosted: Tue Oct 09, 2007 7:42 pm
PostPosted: Thu Oct 11, 2007 6:54 pm
this is the problems i'm left with below;
1- on the loom with the lambda sensor i have these left over;
2- on the bulkhead i have these left over, im guessing they are speed sensor and brake fluid?!?!?;
3- the biggest problem is where the hell do i connect all these wires in my car?
its vertually done tho, just needs tidying
PostPosted: Tue Oct 16, 2007 8:38 pm
i just need to find out if i have missed something off the engine loom plug in pic below.
fiesta si loom.
12 pin plug
1 - brown - ???
2 - green - tacho
3 - brown - fuel pump relay
4 - black - coil pack power
5 - black/red - ecu earth
6 - red - ecu power
7 - brown - ???
8 - brown - ???
9 - brown/white - temp guage
10 - blank---------------
11 - blank---------------
12 - brown - ???
PostPosted: Tue Oct 16, 2007 11:50 pm
In the top pic, top plug looks like lambda, bottom left plug looks
like carbon canister, and middle plug could be a number of things,
in the second pic bottom pic is for the OBD maschine (so you dont
need to put it anywhere) and the other one could be a number of
things.
Also the white block on the back of the coil pack is only used in the
mondeo as far as i know, (my 2.0 has no plug on it).
Hope this helps
emlyn
P.S, will have a look at the wires to see where they go tomorrow
if you like.
emlyn
PostPosted: Wed Oct 17, 2007 9:44 pm
Users browsing this forum: No registered users and 105 guests
