Fiesta-Si.com • View topic - fiesta wings
 Post subject: fiesta wings
PostPosted: Fri Sep 21, 2007 4:49 pm
PostPosted: Fri Sep 21, 2007 5:17 pm
PostPosted: Fri Sep 21, 2007 7:23 pm
to get them off u have to take off the front bumper,
then drill out the spots welds (i f u can't see them there is probably filler over so rub the top of the wing down to find the spot welds
then use a chisel and a hammer and prise the lip up of the wing
then get a angel grinder the slice it down the front of the wing there it meets the front slam panel and at the bottom of the wing and off it comes :)
hope it helps
PostPosted: Sat Sep 22, 2007 11:50 pm
cheers 4 eh help thats wat i thot bt no sure on gtn it on
do i jst weld it or gt selftappers
soz bt im burst bt im very gratful 4 help
PostPosted: Sun Sep 23, 2007 10:22 am
PostPosted: Sun Sep 23, 2007 9:04 pm
PostPosted: Sun Sep 23, 2007 11:17 pm
PostPosted: Sun Sep 23, 2007 11:20 pm
PostPosted: Mon Sep 24, 2007 12:03 am
i don't know really as the wings aren't a stuctural part, welded would b way better tho as thats how ford done it, they must have welded them on for a reason :)
PostPosted: Mon Sep 24, 2007 1:14 pm
thats true it is not a structual part, many other cars have wings bolted on and no welds. yes welds will be safer, im bolting mine on until i can get hold of a MIG, but i cant see how it would be a MOT fail and how it is unsafe?? if done right it should be fine.
PostPosted: Mon Sep 24, 2007 1:58 pm
Because i would of thought that it affects how the car damages during a crash or something similar i.e. being hit from man different angles
Literally it was designed to be welded for a reason, it wont look good if you change the way it goes together from the manufacturer standard, its just how the MOT people will look at it
Some may be kind, some may just stick the boot in for it, welded is shafe ;)
PostPosted: Mon Sep 24, 2007 2:51 pm
PostPosted: Mon Sep 24, 2007 4:09 pm
PostPosted: Mon Sep 24, 2007 4:16 pm
PostPosted: Mon Sep 24, 2007 4:25 pm
lol well ive bolted the tops and welded it onto the valance...
PostPosted: Mon Sep 24, 2007 4:29 pm
 Post subject: Wings
PostPosted: Mon Sep 24, 2007 8:08 pm
 Post subject: Re: Wings
PostPosted: Mon Sep 24, 2007 8:14 pm
PostPosted: Mon Sep 24, 2007 10:11 pm
PostPosted: Tue Sep 25, 2007 7:44 pm
PM if u want u advert here :D
