Fiesta-Si.com • View topic - My cars ticking . .help me
PostPosted: Fri Sep 07, 2007 7:13 pm
PostPosted: Fri Sep 07, 2007 7:19 pm
PostPosted: Fri Sep 07, 2007 7:20 pm
PostPosted: Fri Sep 07, 2007 7:24 pm
PostPosted: Fri Sep 07, 2007 7:27 pm
PostPosted: Fri Sep 07, 2007 7:29 pm
PostPosted: Fri Sep 07, 2007 7:30 pm
If it sounds like this its the tappets
PostPosted: Fri Sep 07, 2007 7:31 pm
it may cause no harm but i bloooooody hate it . . when i test drove it , was completely fine n . .two days later it start typical
umm maybe imma do da oil first before i see ifs its anything else
PostPosted: Fri Sep 07, 2007 8:23 pm
PostPosted: Fri Sep 07, 2007 9:06 pm
PostPosted: Fri Sep 07, 2007 9:16 pm
PostPosted: Fri Sep 07, 2007 9:53 pm
PostPosted: Sat Sep 08, 2007 2:54 am
PostPosted: Sat Sep 08, 2007 7:05 pm
PostPosted: Sat Sep 08, 2007 8:03 pm
tapping on CVH/PTE type engines is pretty common....check the oil level...being hydraulic tappets they are not adjustable....if you start it up..move it..and then shut it off a couple of times they get the arse..once you have checked the oil level...take it out for a good run...10-15 miles or so...then see if it shuts up
Jam
PostPosted: Sat Sep 08, 2007 9:40 pm
could be the oil ways blocked and not enough oil gettin to the head!!! best thing 2 do is get the rocker cover off and have a look inside and then get the sump off and clean out all the pipes as if it is blocked and u dont do it then ur in mega trouble!!!!
Users browsing this forum: No registered users and 105 guests
