Fiesta-Si.com • View topic - inlet manifolds ! ?
 Post subject: inlet manifolds ! ?
PostPosted: Sun May 20, 2007 8:31 pm
hi just bit confused with the 2litre
i was reading few posts and as what i understand is tht the 1.6 inlet manifold is little restricitve on the 2litre
so i would need rs1800 to fit alot better ???? as i am struggling to find this are there an other inlet manifolds with the same size holes ! (ports ) tht i could use instead !
thanks
garry
PostPosted: Sun May 20, 2007 9:07 pm
Rs1800 would be best to use.
Dean
PostPosted: Sun May 20, 2007 10:01 pm
u can use an escort or orion 1.8 manifold but try to getthe 130bhp version as these are the best
PostPosted: Sun May 20, 2007 10:26 pm
you could also use the
2.0 focus inlet, need some modification to some wiring or something
1.8 inlet off the 1.8 xr2i
1.8 inlet off the rs1800/xr3i
1.6 inlet even if it is restrictive
*lol* i have one sat here in my room as well and rs1800 one :p
PostPosted: Mon May 21, 2007 9:27 am
The Nude Numpty
The Nude Numpty
I was told the other day that a 2.0 litre inlet manifold will fit, but will be a squeeze agasint the bulkhead, am I right in assuming he is wrong lol?
PostPosted: Mon May 21, 2007 9:50 am
no the 2.0 mondeo inlet does not fit, it hits the bulkhead, the 2.0 focus manifold is the only 2.0 inlet that we know of that fits straight on
but you have to modify somw wiring to get it to work correctly
here is the link for the 2.0 focus inlet
http://www.teamford.co.uk/webpage/focusinletupgrade.htm
PostPosted: Mon May 21, 2007 11:32 am
PostPosted: Mon May 21, 2007 3:10 pm
PostPosted: Wed May 23, 2007 12:16 pm
Zetec Mapping Services
