Fiesta-Si.com • View topic - smoking si
 Post subject: smoking si
PostPosted: Tue May 08, 2007 6:02 pm
PostPosted: Wed May 09, 2007 12:27 am
PostPosted: Wed May 09, 2007 12:35 am
PostPosted: Wed May 09, 2007 2:40 am
PostPosted: Wed May 09, 2007 3:55 pm
Hi,
only changed the plugs as they were knackered, and it has only started smoking since they were changed i would of said the smoke was greyish blue it is using more oil and none of the other levels have moved
more help please
PostPosted: Wed May 09, 2007 4:08 pm
does it misfire alot?
sounds like its running mega rich.. could be a pooed sensor (MAF at a guess)
PostPosted: Wed May 09, 2007 10:20 pm
If its blue and the oil is going down then it is burning oil,
Maybe valve stem seals, piston rings, or head gasket.
Do a compression test to check the rings.
hope this helps,
emlyn
PostPosted: Thu May 10, 2007 6:14 pm
Hi, just got back from the garage and the engine is fooked the piston rings are worn and when they put oil in the top it came out of the exhaust so any suggestions on what engine to go for next do i have to do the same as everyone else and put a 2.0 in it or can i go bigger
cheers.
PostPosted: Thu May 10, 2007 7:41 pm
You will have to be a sheep and do the 2.0l conversion! No other engines bar the 1.8, but you'll only wish you had put a 2.0l in if you do that!
