Fiesta-Si.com • View topic - stiff steering????...???
It is currently Thu Mar 26, 2026 3:42 am
 Post subject: stiff steering????...???
PostPosted: Fri May 04, 2007 1:13 am
any ideas or tips anyone lol
not sure why but just recently when i turn corners (left &right) there are stiff spots in the steering on the 1.1. (as in stiff then loose then stiff then loose)
its got worse today started about a week ago but wasnt that bad
only happens when moving - when the car is parked steering is normal with engine on & off(it locks)
tends to die down & return to normal if i drive around for ages but when i 1st leave anywhere it must look like i cant drive properly lol
thanks
Breaking Standard Si
PostPosted: Fri May 04, 2007 7:37 am
Before you go spending loads, get your power steering fluid changed. May be an air lock in there somewhere? But that'll be your first and cheapest option.
PostPosted: Fri May 04, 2007 8:32 am
coudl also be the UJ (universal joint)
might need greasing up, as its a common problem on fiestas
u used WD40 on mine when it started to stick and never had any trouble again :)
PostPosted: Fri May 04, 2007 10:15 am
cheers for the replys
des - i wish i had power steering to change it lol only 1.1 94 model no pas or electric pacs:(
moe - this may seem stupid but where would i find this UJ ?
PostPosted: Fri May 04, 2007 10:17 am
drivers footwell just follow the steering column
and then the same place in the engine bay :)
PostPosted: Fri May 04, 2007 10:23 am
PostPosted: Fri May 04, 2007 1:57 pm
PostPosted: Fri May 04, 2007 2:01 pm
PostPosted: Fri May 04, 2007 2:03 pm
PostPosted: Fri May 04, 2007 2:19 pm
PostPosted: Fri May 04, 2007 2:24 pm
PostPosted: Fri May 04, 2007 2:41 pm
PostPosted: Fri May 04, 2007 5:05 pm
the drums off luckily was one of them cylinders in the dum just popped out. cleaned everything and pushed it back in, filled it, left it for a while and no leak :)
do need new brake shoes though part of one is just metal lol would explain grinding noise i hear :)
thanks 4 help Moe
