Fiesta-Si.com • View topic - headunit problems & passenger window & clunky!
PostPosted: Wed Apr 18, 2007 3:30 pm
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Wed Apr 18, 2007 3:36 pm
PostPosted: Wed Apr 18, 2007 3:55 pm
RR - TBC
PostPosted: Wed Apr 18, 2007 4:00 pm
PostPosted: Wed Apr 18, 2007 4:08 pm
PostPosted: Thu Apr 19, 2007 12:26 am
RR - TBC
 Post subject: Problems
PostPosted: Thu Apr 19, 2007 4:08 am
The windows will more than likely be dodgy contacts in your switch, if you are a little tech minded and inquisitve you can take the switch apart noting where and how it all fits and lightly sand the contacts and you will find that should sort your window problem out. Same on the boot lid contacts. Clunking again is more than likely the rear box mount is buggered as it is a very common fault on the escorts & fiestas.
PostPosted: Thu Apr 19, 2007 8:12 am
or instead of doing all that to the swich go to a scrappers and pocket one or two :P
PostPosted: Fri Apr 20, 2007 6:12 am
PostPosted: Fri Apr 20, 2007 8:13 am
lol!!
quite true. i have a yard within walking distance so its not too bad for me
 Post subject: Scrappy
PostPosted: Fri Apr 20, 2007 5:49 pm
Lucky bugger, a decent local one here is about 12 miles away
