Fiesta-Si.com • View topic - tapping video
It is currently Thu Mar 26, 2026 12:49 am
 Post subject: tapping video
PostPosted: Sun Apr 15, 2007 6:18 pm
hey people here is a video of the tapping that ive been having trouble diagnosing cheers scotty
PostPosted: Sun Apr 15, 2007 6:40 pm
Its not one of the belts is it, Fan or Cam breaking up and freying whipping as the engine turns???
PostPosted: Sun Apr 15, 2007 6:51 pm
its definatley not a belt, i heard it last nite
PostPosted: Sun Apr 15, 2007 6:58 pm
i think part of it is a belt but dunno wot the loud tapping is as it goes back to idle!!!! confused lol
PostPosted: Sun Apr 15, 2007 10:03 pm
silly question but have you got oil in that engine ?
PostPosted: Mon Apr 16, 2007 2:46 pm
PostPosted: Mon Apr 16, 2007 3:16 pm
PostPosted: Mon Apr 16, 2007 4:09 pm
PostPosted: Mon Apr 16, 2007 4:12 pm
PostPosted: Mon Apr 16, 2007 5:19 pm
sounds like somthing is dry at the top end, not getting enough oil
PostPosted: Mon Apr 16, 2007 5:30 pm
wot do u think it is thn moe????
PostPosted: Mon Apr 16, 2007 5:32 pm
I'd whip the Rocker cover off and check all is well under there!
PostPosted: Mon Apr 16, 2007 5:39 pm
seems as though its tapping as the cam is spinning maybe a dry tappet?
as chubbyjon said, whip the rocker cover off and look for wear, take a pic if your not sure what your looking for
 Post subject: Tapping
PostPosted: Thu Apr 19, 2007 4:15 am
The tapping is one of your hydraulic cam followers that is weak, does it do it when accelerating or is it just when you are backed off on the over run ? Does it sound like the cavaliers, astras & corsas used to do with a knackered cam. ? Does it do it when hot or cold ?
PostPosted: Thu Apr 19, 2007 9:21 am
it does it mainly when i accelerate but sometimes it does it on idle usually when its both hot and cold always does it with the accelerator no matter whether its hot or cold how much are we looking to get that fixed??? cheers scotty
PostPosted: Thu Apr 19, 2007 5:54 pm
 Post subject: Repair cost
PostPosted: Fri Apr 20, 2007 5:42 am
 Post subject: Cost
PostPosted: Fri Apr 20, 2007 5:52 am
PostPosted: Fri Apr 20, 2007 9:22 am
cheers m8ey:) how much do you reckon a mechanic would charge to fit these if i was to buy them and will this definetely be the tapping and should any local garage be able to do this job???? cheers scotty
PostPosted: Fri Apr 20, 2007 9:27 am
Had a similar sort of noise te other day, but was only when i accelerated i thought it was the tappets and it turned into(a very loud)rumbling/knocking noise, making me think the bottom end had let go. But after i got the car back to the hose i found that one of the egr things goin into the exhaust manifold had worked itself loose and broken off completly. its a very slight possibility but worth checking out just in case. it costs nothing
Users browsing this forum: No registered users and 112 guests
