Fiesta-Si.com • View topic - EGR help please!!!!
 Post subject: EGR help please!!!!
PostPosted: Sat Apr 14, 2007 8:21 pm
Hello,
My 2.0 si has had the EGR removed. Should the sensor on the bulkhead
the that vacuum hose used to got to be blanked or unplugged?
Also the is another sensor(or something) near the expansion tank which
also had vacuum hoses going to it to do with the EGR system. Should this
be unpluged/blanked etc?
The reason I ask is because I am having some idle issues and hope this may
be the cause.
If anyone can help it would be much appriciated.
Thanks
Emlyn
PostPosted: Sat Apr 14, 2007 9:11 pm
i removed mine this weekend and all i did was remove the egr things and blank/block off the hose that goes to that solenoid thingy[lol]
PostPosted: Sat Apr 14, 2007 10:47 pm
the pipe that come from the egr should be blocked but the pipe going from the sensor to the manifold should still be attached and the sensor should be connected coz its suppost to take some measurements of some thing lol
whats wrong with the idleing because it could be the idle speed control valve thats at fault
PostPosted: Sun Apr 15, 2007 11:24 am
oh rite cheers guys I'll give that a bash.
Any idea on that other sensor near the header tank?
should it be plugged in etc.?
Mouse- its not the ISCV as its been replaced twice now but cheers
for the idea.
thanks
emlyn
PostPosted: Sun Apr 15, 2007 3:24 pm
sensor is to do with the fuel vapour system (carbon box). needs to be plugged in and has vacuum to the inlet manifold
PostPosted: Sun Apr 15, 2007 5:42 pm
goaty- cheers mate, mine also seems to have a blue plastic insert
half way along the hose to the manifold, it looks to be some sort
of thing to restrict air flow as it has a very small hole inside it.
should i take it out or does it need to be there?
many thanks
Emlyn
PostPosted: Sun Apr 15, 2007 6:05 pm
leave it in
Users browsing this forum: No registered users and 120 guests
