Fiesta-Si.com • View topic - Camber...
 Post subject: Camber...
PostPosted: Wed Mar 07, 2007 2:55 am
I know that lowering the fiesta does affect the camber of the front wheels.. but fook me, mine looks well bad, and it ate 2 tyres recently on the inside.
Does tracking alter the camber at all?
I never got it tracked after we lowered it 40mm, which I should get done,
But as I said, I was wondering if the camber is altered when the tracking is set up?..
Cheers guys.
Paul.
PostPosted: Wed Mar 07, 2007 9:28 am
No, tracking only sorts out the toe in/toe out side of things. You can get the camber done at the same time, but you have to specify it. Plus I don't believe the Fiesta's camber is adjustable as standard? I had to get camber adjustment bolts fitted to my Pulsar so the camber could be sorted.
The bolts basically have a cam on them which, when turned, adjust the camber. All this can be done when set up for the tracking, but will cost you more.
PostPosted: Wed Mar 07, 2007 1:51 pm
Zetec Mapping Services
PostPosted: Wed Mar 07, 2007 3:24 pm
PostPosted: Wed Mar 07, 2007 3:30 pm
PostPosted: Wed Mar 07, 2007 3:36 pm
ive ordered a set £290 areas six arms with rose joints and adjustable ball joint for camber i should get them ne day soon, any fiesta lower than 40mm would have had the camber altered :)
heres a pic of them
How much would you do them for saqmaster?
And would they be safe? :lol:
Seen them ones, but £290 is steap and i'd rather just keep replacing my front tyres every 6 months :lol:
PostPosted: Wed Mar 07, 2007 3:38 pm
PostPosted: Wed Mar 07, 2007 3:44 pm
PostPosted: Wed Mar 07, 2007 3:58 pm
PostPosted: Thu Mar 08, 2007 12:27 pm
i dont like the look of the area six ones, look like the could slip out of place at anytime.
PostPosted: Thu Mar 08, 2007 12:29 pm
They cant. You'd understand if you saw how they were done without the bolts in 8)
PostPosted: Thu Mar 08, 2007 12:34 pm
PostPosted: Thu Mar 08, 2007 1:07 pm
PostPosted: Thu Mar 08, 2007 1:35 pm
PostPosted: Sat Mar 10, 2007 3:34 pm
PostPosted: Sat Mar 10, 2007 10:13 pm
Zetec S alloys which fit better than the 14inch standard si ones
15inch 45profile 195 wide.
Lowered 40mm, and tracking out. :lol:
PostPosted: Sun Mar 11, 2007 3:01 pm
