Fiesta-Si.com • View topic - Blue smoke i think i found problem need help *updated 23/02*
PostPosted: Wed Feb 21, 2007 10:46 pm
PostPosted: Wed Feb 21, 2007 11:38 pm
PostPosted: Wed Feb 21, 2007 11:50 pm
PostPosted: Thu Feb 22, 2007 1:17 am
haynes says: 5W/50 to 10W/30
i use 5w50 in mine
PostPosted: Thu Feb 22, 2007 1:46 am
always always 5w/50 fully synthetic if you can afford it. :)
PostPosted: Thu Feb 22, 2007 3:33 am
ive always used 10W40 & never had a problem, its 1.1 though
was told to use this one when i first got a car so always used it never thought to look it up. maybe i should go check lol :oooh:
Breaking Standard Si
PostPosted: Thu Feb 22, 2007 8:54 am
PostPosted: Thu Feb 22, 2007 11:44 am
you're all wrong
correct oil for use in ford zetec engines is 5w30 semi synth
PostPosted: Thu Feb 22, 2007 12:01 pm
:? why does the haynes say 5w/50 ?
silly haynes!
PostPosted: Thu Feb 22, 2007 12:08 pm
is that for zetec or cvh?
PostPosted: Thu Feb 22, 2007 12:10 pm
tis for zetec
PostPosted: Thu Feb 22, 2007 12:14 pm
very strange. i know ford say use 5w30 and i'd listen to them over Haynes for some reason
PostPosted: Thu Feb 22, 2007 12:29 pm
PostPosted: Thu Feb 22, 2007 12:38 pm
PostPosted: Fri Feb 23, 2007 8:46 pm
PostPosted: Fri Feb 23, 2007 8:53 pm
PostPosted: Fri Feb 23, 2007 9:17 pm
PostPosted: Sat Feb 24, 2007 2:36 am
full 5 litres!!!
mine normally takes just over 4
PostPosted: Sat Feb 24, 2007 5:16 am
Daft question but have you run it with the oil in yet?
All I can think of doing is let it go round the system a bit then check the dipstick later on to see if it catches up. All I can suggest unfortunately :(
PostPosted: Sat Feb 24, 2007 12:24 pm
