Fiesta-Si.com • View topic - erratic idle
It is currently Wed Mar 25, 2026 11:19 pm
 Post subject: erratic idle
PostPosted: Tue Feb 13, 2007 10:30 pm
my fezz seems to be erratic on idle and rough on acceleration.
It revs itself on idle between 800rpm and 1500rpm and when accelerating it seems abit rough. can anyone tell me what this might be.
im guessing idle speed control valve on first issue but not 100%. input needed :)
cheers
PostPosted: Tue Feb 13, 2007 10:39 pm
try unpluging your tps, its what was wrong with mine, if not then i would say idle controll valve 8-)
PostPosted: Tue Feb 13, 2007 10:44 pm
PostPosted: Tue Feb 13, 2007 10:48 pm
PostPosted: Tue Feb 13, 2007 10:59 pm
PostPosted: Tue Feb 13, 2007 11:13 pm
PostPosted: Tue Feb 13, 2007 11:17 pm
PostPosted: Tue Feb 13, 2007 11:41 pm
PostPosted: Tue Feb 13, 2007 11:42 pm
PostPosted: Wed Feb 14, 2007 2:18 am
as above.. but the TPS works on resistance of how open it is..
so the ecu knows exactly where it is all the time
PostPosted: Wed Feb 14, 2007 8:57 am
PostPosted: Wed Feb 14, 2007 9:43 am
PostPosted: Wed Feb 14, 2007 10:10 am
PostPosted: Wed Feb 14, 2007 11:18 am
PostPosted: Wed Feb 14, 2007 12:04 pm
i thought they were just plug and play ?
PostPosted: Wed Feb 14, 2007 12:47 pm
no, they need setting up. if you look at it you can see that if you lossen off the fixings it can twist either way.
PostPosted: Wed Feb 14, 2007 9:32 pm
PostPosted: Wed Feb 14, 2007 9:40 pm
PostPosted: Wed Feb 14, 2007 10:55 pm
PostPosted: Thu Feb 15, 2007 12:14 am
Users browsing this forum: Google [Bot] and 82 guests
