Fiesta-Si.com • View topic - PATS go poo, need help!!!
It is currently Wed Mar 25, 2026 11:19 pm
PostPosted: Mon Feb 05, 2007 8:00 pm
PostPosted: Mon Feb 05, 2007 8:06 pm
Put your old reciver on,dis-connect battery, leave overnight re-connect battery in the morning hopefully the ECU should have reset its self and PATS should have hopefully picked its dummy up! :)
Its worth a try if anything!
JDFiesta had this problem, he just left the car overnight went to start it next day and it worked fine, PATS had just spat its dummy out! :(
PostPosted: Mon Feb 05, 2007 8:11 pm
PostPosted: Mon Feb 05, 2007 8:13 pm
PostPosted: Mon Feb 05, 2007 8:15 pm
PostPosted: Mon Feb 05, 2007 9:07 pm
PostPosted: Tue Feb 06, 2007 9:53 am
PostPosted: Tue Feb 06, 2007 10:49 am
PATS is NOT internal on the Si
PATS is external, hence why you dont have to change keys etc when you swap ECU's.
you're thinking of EDIS
£70 IIRC from ford to reprogramme it
you got a spare key? it may be your key thats buggered?
PostPosted: Tue Feb 06, 2007 9:48 pm
PostPosted: Wed Feb 07, 2007 11:00 am
behind the dash, and it's glued to bulkhead/dash IIRC
PostPosted: Wed Feb 07, 2007 1:00 pm
PostPosted: Wed Feb 07, 2007 2:04 pm
i'm not saying it will cure your problem for definate but if you change the pats module and key etc they should work fine if they're matched
Worth a try though
PostPosted: Wed Feb 07, 2007 2:20 pm
Users browsing this forum: Google [Bot] and 82 guests
