Fiesta-Si.com • View topic - Gearbox
 Post subject: Gearbox
PostPosted: Mon Feb 05, 2007 1:15 am
Sig. made by xmadxmoex
PostPosted: Mon Feb 05, 2007 1:37 am
PostPosted: Mon Feb 05, 2007 1:40 am
PostPosted: Mon Feb 05, 2007 1:59 am
PostPosted: Mon Feb 05, 2007 4:39 am
the knocking noise sounds like a mount.
the other problem is clutch related.
when you fitted new both did you tension clutch cable up?
has yours got automatic or manual adjust clutch?
PostPosted: Mon Feb 05, 2007 12:42 pm
PostPosted: Mon Feb 05, 2007 12:43 pm
PostPosted: Mon Feb 05, 2007 12:45 pm
PostPosted: Mon Feb 05, 2007 3:29 pm
PostPosted: Mon Feb 05, 2007 3:31 pm
PostPosted: Mon Feb 05, 2007 3:33 pm
PostPosted: Mon Feb 05, 2007 3:39 pm
PostPosted: Mon Feb 05, 2007 3:56 pm
PostPosted: Mon Feb 05, 2007 3:59 pm
PostPosted: Tue Feb 06, 2007 11:04 am
look at your clutch pedal. is there a white knob on the front of it, just above where your foot goes? if so it's manual
PostPosted: Tue Feb 06, 2007 11:09 am
Mounts are a fairly easy task, you just have to take quite a bit off to get to them.
it's advised to change them both
jack car up and support on axle stands.
remove 'S' Shaped brace from under car
Using a bit of wood on face of jack support the engine weight.
remove the 2x 17mm nuts for gearbox mounts on cradle.
remove cradle
remove mounts from gearbox
fit new ones
secure cradle to box using mounts.
use Jack to postion cradle onto mounting holes and secure cradle.
ensure it is all tight
Fit 'S' shaped brace. make sure the cat hangers are refitted.
lower car etc and away you go
thats a brief explanation
PostPosted: Tue Feb 06, 2007 7:48 pm
PostPosted: Wed Feb 07, 2007 11:02 am
check your engine earths before replacing sender unit
good socket set, axle stands, and jack is all you need, maybe a couple of spanners
Users browsing this forum: No registered users and 119 guests
