Fiesta-Si.com • View topic - my sub has decided to disfuction :(
It is currently Wed Mar 25, 2026 4:57 pm
PostPosted: Thu Jan 04, 2007 7:03 pm
PostPosted: Thu Jan 04, 2007 7:04 pm
PostPosted: Thu Jan 04, 2007 9:38 pm
ive had this before its bad connections in the back of the sub. take the sub outa the box if you can see a wire has frayed your ok if you cant the its probably frayed in the cone and you need a new sub unless its might expensive and you can get cone replacements but they aint worth it unless your sub cost more that £300.
try playing with your amp setting aswell just on the off chance
PostPosted: Thu Jan 04, 2007 9:54 pm
PostPosted: Thu Jan 04, 2007 10:08 pm
i take it you connected it up to the rear light earth below one of the lights on the inside, if you have make sure you have the earth for the amp on the metal and then the rear lights earth. if you lights then play up you know its an earth :)
works for me...ive had way to many subs to think about :lol:
heres a pic of the boot on my last fiesta :lol:
back then i used to think it looked amazing now i think it looked tacky as hell :lol:
that was some fun wiring that up...theres another 2 amps behind the seats :)
PostPosted: Thu Jan 04, 2007 10:14 pm
hi that set up looks loud lol i onli got a single and 6x9s lol . na my earth is behind the seats in the floor i got the max power haynes modding guide for fiestas and followed what it said in there lol may put it on the lights now thanks :lol:
PostPosted: Thu Jan 04, 2007 10:25 pm
it was loud.lol the subs on the sides were 700w each and the middle was 1200w i had one 1500w amp runing the two side subs one 600w amp running the middle and one 500w running the speakers. they werent all the same amps tho so i put two behind the seats 2 make it look tidy...well tidier.lol
i would try just below the light theres a good earth on both sides. theres a bolt potruding from both sides of the body and it works fine for the lights so no reason for not doing the sub aswell...if that doesnt work take the sub outa the box and look at the connections
