Fiesta-Si.com • View topic - new sub and amp???
It is currently Wed Mar 25, 2026 4:56 pm
 Post subject: new sub and amp???
PostPosted: Fri Dec 29, 2006 1:02 am
PostPosted: Fri Dec 29, 2006 10:38 am
all wires connected correctly?
Earthed? remote wire attached?
PostPosted: Fri Dec 29, 2006 4:05 pm
yea...i did everything, thats why im confused.... :x
PostPosted: Fri Dec 29, 2006 4:10 pm
fuse in power lead?
PostPosted: Fri Dec 29, 2006 4:18 pm
uhuh...i checked it, is a brand new wiring kit so i kno they are fine....is there something im missing?
the only thing i can think of is that im using my old headunit, but i dnt see how this is a problem
PostPosted: Fri Dec 29, 2006 4:23 pm
what exactly is happening? any lights coming on amp?
PostPosted: Fri Dec 29, 2006 4:34 pm
there are no lights on it....so am not even sure if the amp is on...
PostPosted: Fri Dec 29, 2006 5:40 pm
PostPosted: Fri Dec 29, 2006 7:07 pm
PostPosted: Fri Dec 29, 2006 7:17 pm
my mate had one.
they have a blue led which lights up when they are on obviously.
my mates unit was nadged after a couple of uses - not even pushing it.
i dont rate their build quality - he had to return his because we couldnt cure it, and then get a replacement unit. nice. :lol:
PostPosted: Fri Dec 29, 2006 7:19 pm
i dnt mind it...it only cost me 36 quid from ebay with a capacitor aswell :lol: :lol:
PostPosted: Fri Dec 29, 2006 7:24 pm
well, no, i dont think you catch my drift, they sound good and dont look too bad, but they are built like a boy scouts raft!
try running a short piece of wire between your constant +12v (big red wire from battery), and the remote terminal on the amp (just a short jumper wire), if it lights up you know you've put your remote wire to the wrong terminal on the back of your headunit..
PostPosted: Fri Dec 29, 2006 7:28 pm
oh :(
well i will give that a go...cheers :)
PostPosted: Fri Dec 29, 2006 7:34 pm
if not double check your earth point like jd said, i know they need quite a big, nice, juicy bit of clean metal
PostPosted: Fri Dec 29, 2006 8:32 pm
ok....i have earthed it to a bolt in the boot.....thanks for your help
