Fiesta-Si.com • View topic - magnex b/box GRRR
It is currently Wed Mar 25, 2026 8:36 pm
 Post subject: magnex b/box GRRR
PostPosted: Tue Dec 12, 2006 6:22 pm
im having a small problem with my "custom made" magnex b/box. its only a temporary box till i got money for a full system. becos its a ford custom fit for an Si - it doesnt fit my Si :homo: ive had to slightly expand the zorst pipe tip for it 2 fit on. then i tried GunGum and a metal sleeve thing to seal the gap becos it wobbles and leaks like a salad. then i recently tried QuikSteel. aparently it turns to steel and can take high temps. but this has cracked on the pipe joint.
what can i actually use to seal the gap? and how coslty is welding?
chars!
PostPosted: Tue Dec 12, 2006 6:32 pm
It may be quite expensive to weld the exhaust as stainless steel welding is different to normal welding! :|
May be cheaper to buy a Si magnex backbox! :)
PostPosted: Wed Dec 13, 2006 12:51 am
PostPosted: Wed Dec 13, 2006 11:00 am
i take it you mean you;ve got a universal magnex back box
just buy the proper one for car
