Fiesta-Si.com • View topic - clutch
It is currently Wed Mar 25, 2026 4:56 pm
 Post subject: clutch
PostPosted: Sun Dec 10, 2006 10:30 pm
PostPosted: Sun Dec 10, 2006 10:38 pm
PostPosted: Sun Dec 10, 2006 10:42 pm
PostPosted: Sun Dec 10, 2006 10:45 pm
locate the pedal cable it should be just below the battery tray or around tht area get some1 to keep pushing the pedal down nd keep em doin tht while they do it spray some lub ect like wd40 so tht it goes into or onto the cable it should feel better
PostPosted: Sun Dec 10, 2006 11:01 pm
try to use a silicopne lube as it will last longer and wont wash out if your driving in the rain as easily
PostPosted: Sun Dec 10, 2006 11:06 pm
PostPosted: Sun Dec 10, 2006 11:23 pm
PostPosted: Sun Dec 10, 2006 11:29 pm
coulnt tell you, i would say try it and see but that may prove a bad decision. just get silicone lube in a spray can that, that has a pipe type thing (like you get with WD40) and put it angainst the end of the outer and squirt away.
as xmadxmoex says, it would be beneficial to replace it though, the lube will buy you some time though!!!
