Fiesta-Si.com • View topic - Door lock .....
It is currently Wed Mar 25, 2026 4:56 pm
 Post subject: Door lock .....
PostPosted: Sat Nov 11, 2006 4:33 pm
Fiesta 1.6 Si Door will not open from the outside at all . have to lean across and open it from the passenger side also inside handle always in locked postion, been in to investigate and have found the famous offending spring in the bottom of the door ? but space a little tight and can't get in to find out whats goes where ? anybody got a diagram or any tips ??? is a case of just hooking the spring back in place ? :? :? :? :?
PostPosted: Sat Nov 11, 2006 5:36 pm
PostPosted: Sat Nov 11, 2006 11:05 pm
gotta love the spring! bane of my fiesta ownership, take doorcard off, wind window up, unscrew lock cover/window runner, pull that white plastic guard off. if i remeber rightly its obvious, there is a hook and an oval shaped hole, go for it bra!
if needs be look at the other door lock for guidence.
 Post subject: bloody doors
PostPosted: Sat Dec 16, 2006 5:25 pm
:) yup all done . had to get a little physical but all ok . had too look at the passenger door to see where it goes . don't know what world lock designers live in but i don't want to go there :? :? :? :? :?
