Fiesta-Si.com • View topic - My mk3 si 1.6 keeps going flat.
It is currently Wed Mar 25, 2026 3:24 pm
PostPosted: Tue Sep 26, 2006 11:28 am
PostPosted: Tue Sep 26, 2006 11:59 am
PostPosted: Tue Sep 26, 2006 12:02 pm
PostPosted: Tue Sep 26, 2006 12:32 pm
PostPosted: Tue Sep 26, 2006 12:39 pm
PostPosted: Tue Sep 26, 2006 12:54 pm
something's draining the battery. check you auxilary stuff.
do you have an amp+sub? if so try disconnecting the amp and see if that makes a difference then. also check that boot interior light is going off when tailgate is shut
PostPosted: Tue Sep 26, 2006 1:16 pm
yea have thort of that when i had the AA out they did a power test on the battery cables it showed there was no power comeing from the battery???
tis drivin me up the wall lol
PostPosted: Tue Sep 26, 2006 2:16 pm
I had the exact same problem when I got my si. Bought a new battery, everythin seemed fine....until the morning. Completley flat again. Jumped started it with leads, started fine so starter motor was ok. I tested the voltage on my battery while running.... 10V :o Should be 14V ish. So replaced the alternator £10 from scrap yard. Problem solved :) :)
Kev Ess
1.4 Si , ITG Induction Kit, Wing-back Seats (Some nice alloys & lowered next plan)
PostPosted: Tue Sep 26, 2006 2:42 pm
yea i thort that but after i have been drivin it seem fully charged only when i leav it it goes flat u think it is the alternator drain the battery but the aa said they could not find a drain on the battery from the main cables connected to it.
PostPosted: Tue Sep 26, 2006 3:09 pm
The alternator may not be charging your battery properly, so although it may seem fine after a bit of a drive, it actually may not be fully charged, therefore not holding any life it has in it. Alternator shouldn't be draining any power, which is why it would not have shown up on a test for drainage :)
PostPosted: Tue Sep 26, 2006 3:20 pm
ok if u think it could be that it just seems to be very strange realy.
so u think it will be the alternator.
PostPosted: Tue Sep 26, 2006 11:47 pm
I ahd this problem with one of my old fezzies and then mine started doin it while driving when i called out the rac they checked it all over n it ended up bein coroded terminals on the cable tht connected to the starter motor !!!
PostPosted: Wed Sep 27, 2006 8:06 am
PostPosted: Thu Sep 28, 2006 9:16 am
start the car. use a multimeter to check voltage on battery. should be ~14v
