Fiesta-Si.com • View topic - Clutch not engaging properly?
It is currently Wed Mar 25, 2026 3:26 pm
PostPosted: Mon Aug 28, 2006 6:53 pm
I think my clutch ratchet thingy has allmost died, basically im getting alot of up and down movement, before it the clutch actually starts to move.
Ive put it down to this? any thing else it could be and is it hard/easy to sort out?
James
 Post subject: clutch
PostPosted: Mon Aug 28, 2006 9:33 pm
hi there mate iw ould check the cable it could have streched does the clutch slip if so clutch is nackard. could be the ratchet on the pedel box check it see wat you think let us know i got msn if you want to chat wobbie_b@hotmail.com
PostPosted: Mon Aug 28, 2006 9:39 pm
do you mean "free play" before the clutch starts to engage?
if you mean free play then it could well be both cable and ratchet, obviously change cable first as thats only going to be in the region of £20.
Clutch slip test:
one method is, go on roadtest, go up a reasonably steep hill at about 50mph, pull the handbrake on gently and see if the revs increase more than the speed.. that would indicate slipping clutch i believe?
PostPosted: Mon Aug 28, 2006 10:42 pm
Cable is fairly new actually, this is my second in the last few months.
Yea its free play, like sometimes it will click to one position and be feel tight, the next it will click to another and feels like the clutch has only moved half way.
I dont think the clutch is slipping, well it might be when the ratchet bit dont release properly.
Sometimes it feels tight, the next its loose! I can hear a click sometimes, usually after the click it goes tight.
PostPosted: Tue Aug 29, 2006 7:04 pm
bugggerrrr...
does sound like your clutch ratchet mech is a bit nadged mate :(
even the mouse about the house reckons its a bit of an arsehole to fit..
(searching forum)..
PostPosted: Wed Aug 30, 2006 12:52 am
PostPosted: Wed Aug 30, 2006 7:58 am
Users browsing this forum: No registered users and 95 guests
