Fiesta-Si.com • View topic - welding and gear box
 Post subject: welding and gear box
PostPosted: Mon Jun 19, 2006 8:01 pm
hi i dont suppose sum one could post a idiots guide to welding up here want to try if possible to weld a new sill on :) or is this way to difficult for sum one inexperienced to do? also i had a leak on the gearbox twice now two different mecanics said it was a cracked gasket, it was replaced twice last time 4months ago [the gasket not the gearbox] and was fine but now a leak has appeared from the same place again :x what would have made it crack again? appreciate sum help
PostPosted: Tue Jun 20, 2006 7:14 pm
PostPosted: Wed Jun 21, 2006 10:30 am
PostPosted: Wed Jun 21, 2006 11:35 am
PostPosted: Wed Jun 21, 2006 6:37 pm
sorry its the rear sump sill, [rear oil sump gasket or something] i spose the welding is a body shop job then
PostPosted: Wed Jun 21, 2006 6:40 pm
thanks jam mite try that stuff although i think its going to take more than that :frown:
PostPosted: Sat Jun 24, 2006 2:55 pm
so its not the gearbox? its the sump?
new gasket only gona be about 10 quid surely?
drain the oil,
take the sump off,
fit new seal,
refit sump
:look:
welding sills - eeks :o
PostPosted: Sat Jun 24, 2006 2:59 pm
if its the rear main oil seal then you gona enjoy fixing that :lol:
PostPosted: Sun Jun 25, 2006 11:53 am
there about 30 quid i think, just annoying it keeps going????? :| and it is the rear main mate, :? fun and games!
